ECU code question
1 Post
ECU code question
The speedo does not work in my CRX, so naturally it will throw a code 17
but recently it seems to be throwing out 2 code 1s
The ecu will blink once, pause, blink again, pause, then blink seventeen times. and repeats
why would it throw out the code 1 twice in a row??
[Modified by azroth, 7:12 PM 9/6/2002]
Re: ECU code question (azroth)
how do u know that the O2 sensor its not bad
code 1 its oxygen content......
make sure ur O2 its within specs... reset ecu and see if they still there......
1 Post
Re: ECU code question (Jared)
I am using a 89 crx Si ecu... There is NO code 2 i am sure it was flashing 2 code ones... I thought it might be a code "two" but there is too much of a gap in between flashes... I Changed the FPR And the EICV, and the code is gone... But there is still one sensor on the Intake manifold that did not match up with the HF wireing harness it is on the bottom, right of the intake, and it is NOT the intake temp sensor. I still dont know why it was flasing two of the same code. I just have not seen that before.
delsol93
06-21-2001 02:54 PM
