help neg. battery terminal
where does the neg. battery terminal bolt onto the engine at? doin auto to manual now need to hook battery back up.
Re: help neg. battery terminal (MrTodd)
It's the clutch cable bracket located on the tranny. Make sure the ground is also connected to the chassis.
Have fun.
Have fun.
but on the chassis part.. make sure the valve cover ground wire is going to the chassis
1 Post
Re: help neg. battery terminal (madeiniraq)
While your at it, make sure the thermostat housing ground wire is connected also!
I think those are the only 3 grounds... Negative battery to chassis and tranny. Valve cover to chassis (oops, said tranny at first). Wiring harness to thermostat housing - oh wait! There's another ground wire that connects to the starter motor I think.
[Modified by MrTodd, 9:24 PM 10/10/2002]
obuhmyuh
13
02-11-2008 05:44 PM
