valve cover torque?
Old 01-15-2003, 06:22 PM
91SIvic's Avatar
Default valve cover torque?
i need the valve cover torque... what am i suppost to torque it to?
thx
Old 01-15-2003, 06:24 PM
91_hatch_si's Avatar
Default Re: valve cover torque? (91SIvic)
50
Old 01-15-2003, 07:21 PM
91SIvic's Avatar
Default Re: valve cover torque? (91_hatch_si)
seriously!? that tight?
thanks!
Old 01-15-2003, 08:09 PM
Brrraaaap!
Blaze45's Avatar
dude the little silver studs on the valve cover? 50 ft lbs will bust em OFF! 18 ft lb is the proper spec. I trq'd mine to like 19 and the lil bastard broke off! 50 is way to tight for the little silver studs on the valvecover. hope its not to late....
Blaze
Old 01-15-2003, 08:42 PM
91SIvic's Avatar
Default Re: valve cover torque? (Blaze45)
ok thanks for the heads up...
Old 01-15-2003, 09:10 PM
shortyz's Avatar
i thought it was 18 inche poounds..
u might wanna check that out..
Old 01-15-2003, 09:38 PM
91SIvic's Avatar
Default Re: valve cover torque? (shortyz)
yeah Blaze45 said 18 pounds too...
thanks though! im glad 2 people agreed though.
means i can probably go ahead and put it back on tomorrow. is there a gasket needed? (im fairly new at this)
Old 01-15-2003, 09:52 PM
drjondurst's Avatar
the last dude said 18 INCH pounds.. the other guy said 18 FOOT pounds..
Old 01-15-2003, 09:58 PM
91SIvic's Avatar
Default Re: valve cover torque? (drjondurst)
oh.. lol it would be foot pounds wouldn't it?
Old 01-15-2003, 10:02 PM
Kamin's Avatar
50
your a dumbass.
please step away from the computer.
i just tighten them with a wrench (no specific torque), its not that important, just so you get a good seal with the gasket. about 5-10 ftlbs
Old 01-15-2003, 10:05 PM
shortyz's Avatar
84 inch pounds
9 N.m
that would be 7 ft lbs then wouldnt it?
thats the correct torque specs i checked mitchell.
[Modified by shortyz, 11:10 PM 1/15/2003]
Old 01-15-2003, 10:16 PM
91SIvic's Avatar
so about 7 foot lbs of torque should do?
ok thanks everyone for your help. i just didn't wanna mess anything up.
Old 01-15-2003, 10:56 PM
unabonger's Avatar
Just tighten it by hand, you'll feel when its enough, it doesn't really matter, just not 50 lbs though. Only thing you really need to measure is everything under the valve cover.
Old 01-16-2003, 06:13 AM
Brrraaaap!
Blaze45's Avatar
Default Re: valve cover torque? (unabonger)
my bad, if you have trq. wrench trq. em to 18. Not sure what they measure the tighting w/ but i was thinkin hp/trq when I said ft lbs. sorry. Be sure to hook up your engine ground and a new gasket will keep oil from leaking out.
Good Luck
Old 01-16-2003, 07:00 AM
REDBARON's Avatar
According to the Helms, it's 7 lb-ft.
Later.
Old 01-16-2003, 07:08 AM
New User
wuhungsixxx's Avatar
Default Re: valve cover torque? (REDBARON)
as tight as you can get em with 2 fingers is my rule...unless your hopped up on roids
...yea i always thought it was 7lbs. too
[Modified by wuhungsixxx, 8:09 AM 1/16/2003]
twkdCD595
10-22-2021 02:10 PM
AndThenYouSay
01-18-2010 05:19 PM
julianbc2
12-30-2008 04:14 PM
acmoc
07-03-2008 05:39 PM
1fastGSR
10-01-2001 04:20 PM
Quick Reply: valve cover torque?
