lowering springs????
does anyone know if h&r springs from a 99 civic will lower my 89 crx??? will they fit and will they lower it at least 1.75 inches to 2.5 inches???
Re: lowering springs???? (Phat_GSR)
Are they OE, Sport, or Race springs? Either way, the spring rate will be stiffer.
[Modified by cr-tegra, 5:36 AM 3/10/2003]
Re: lowering springs???? (cr-tegra)
i dont know if they will fit on the spring perches perfectly..my 95's would fit nice on my 88 so i ditched them..ur front may be a lil higher since the struts and springs are lil taller on the newer civics
Location: With my POS D15B2, Whereever whenever, United States
Re: lowering springs???? (mr. skelly)
essentially they will fit, why do you think they have 88-00 coilovers and etc.
The thing is the lowering will be different because the weight of the car is different.
Re: lowering springs???? (MugenHonda)
Re: lowering springs???? (RaceFacer)
this is true...if you sit on your car somewhere your car will lower more...which is the same thing as having a heavier car...if the springs were on a heavier car and you put them on an ef then the car will sit higher because the ef is so light
