b16 Second Gen....1/4 time..Got better........
sup yall.......ran my car after the dissapointing times last time i posted.......i ran again today and hit 15.598......best out of three runs.........i stll want to know why my trap speed is so low though? i am only at 84-86mph at the most when im done for the quarter mile.....things since last post before the track........i changed both o2's, cap rotor, pcv valve.......plugs and wires i did before.......what else can it be fellahz about my trap speed?!?!?! i should be around 90mph +........thanx
Wow that is rough, I recently ran my friends EG this past Sunday he has a 1st gen b16 with full interior, with just i/e and he is running a gsr p72 ecu and I hit a 15.03 on 13 bald steelies with a 60' of 2.2 and a trap speed of 90.xx, how is your traction and ****, good tires will help A LOT ,my first run in his car was a 15.8 ( bad traction ), next was a 15.5 ( lil better ), then the 15.0. With some good tires I am sure I could bang a 14.8, on the 15.0 run my reaction time was a .894 which is horrible
Re: b16 Second Gen....1/4 time..Got better........ (richierich)
post ahead the whole numbers on the best timeslip
that way we can tell if u loosing low end power, top end, u missing a gear, or what
its hard to predict whats wrong with ur car by just a ET .....
i have seen a lot of fast cars runnnig slow.. and its drivers fault....
like RSX T-S runing 16, as a CRX B16 and a CRX ZC... and a 00SI on 15.7's///
so just post the timeslip and we can predict where ur loosing power and give u better answer..... IMO dont really take our guessing opinion.... take it to someone that can really look in ur car and knows.... that might give u better answers
Re: (richierich)
Are you sure that your timming isnt off? Some guy had his off by one tooth and he was running 15.8s. This is a rumor, but maybe you have the auto cams?
Blaze
Blaze
something is pretty strange with that timeslip........
here is my best time so far:
r/t .317
60ft - 2.49
330ft- 6.5
1/8 - 9.953
mph- 73.32
1000 12.82
1/4- 15.2 @ 93
r/t .317
60ft - 2.49
330ft- 6.5
1/8 - 9.953
mph- 73.32
1000 12.82
1/4- 15.2 @ 93
compare that with his............
seems like his gearing is a lil weird......... what trans are you using??? maybe he is shifting way tooo late and not getting any more pull out of his setup.......... try shifting a lil sooner
car runs clean.....no bog.....no nothing........but i kno it could be runnin better.........idles fine runs fine.......new o2, plugs wires cap rotor....pcv.....the thing that i want to kno is that.....why does it rev up slow from 1-5rpm........the rpm's should jump up quicker.......
Re: (richierich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richierich »</TD></TR><TR><TD CLASS="quote">the thing that i want to kno is that.....why does it rev up slow from 1-5rpm........the rpm's should jump up quicker.......</TD></TR></TABLE>
lack of torque
lack of torque
ATS*VEEE
38
08-19-2003 11:47 AM
RCautoworks
12-12-2002 01:54 PM
