seatbelt recall on honda's
Old Jul 15, 2003 | 09:53 AM
jfoxmatt711's Avatar
Default seatbelt recall on honda's
is it true that if your seatbelts don't retract fully when undone you can get them replaced for free at the dealership. I think this might be for any car, but I only care about my civic, my only love
Old Jul 15, 2003 | 09:56 AM
RCautoworks's Avatar
Default Re: seatbelt recall on honda's (jfoxmatt711)
Yes it is true, but I have heard some Honda dealers trying to say its more of a fashion fix or something and they try to back out of it.
Old Jul 15, 2003 | 09:57 AM
Home Skillet's Avatar
For what years?
Old Jul 15, 2003 | 09:58 AM
Default Re: seatbelt recall on honda's (90blackcrx)
By the way here is the list of recalled things and other things people reported or had problems with.
Bulletins for 1990 Honda CRX HF L4-1493cc 1.5L SOHC (D15B6) MFI
Safety Recalls
TSB Number Issue Date TSB Title 95028 OCT 95 Recall - Front Seat Belt Buckle
Service Bulletins
TSB Number Issue Date TSB Title 00-089 OCT 00 Supplemental Restraint System - Inspection
99-018 APR 00 Required Special Tools And Equipment,
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
97-015 DEC 99 Service Publications - Availability & Ordering
99-030 MAY 99 Recommended Materials
19_1-04 OCT 98 Interior - KRYTOX(R) Fluid Applications
98-051 AUG 98 Special Tool Loan Program
98-026 APR 98 Audio Unit - Antitheft Code Labels
98-018 APR 98 CV Joint Boot - Band Tool
98-001 FEB 98 Engine/Transmission - Hydraulic Lift Truck usage
90-007 MAY 97 90-007 - 05/27/97
86-020 MAY 97 Brakes - Disc Refinishing Procedure
97-027 MAY 97 Tools - Denso HLD-100 Halogen Leak Detector
97-028 MAR 97 Body - Minor Paint Finish Repair
97-020 MAR 97 Tools - New Fuel Pressure Gauge and Replacement Parts
96042 SEP 96 Tools - Power Steering Pressure Gauge
89029 MAY 96 Radio - Warranty Exchange/Out Of Warranty Repair
89004 MAY 96 Required Special Tools & Equipment
96014 FEB 96 Tools - Belt Tension Gauge Calibration and Repair
96005 JAN 96 Engine - Idle Vibration or 'Click'
91030 JAN 96 Seat Belt - Slow to Retract
92012 JAN 96 Seat Belts - Warranty Replacement Policy
89029 DEC 95 Radio - Unit Diagnosis
90007 AUG 95 Service Publications and Supplies
89029 MAR 95 Radio - Unit Exchange/Repair
90014 SEP 94 A/T - Remanufacturing Exchange Program
94025 AUG 94 Steering - Wheel Oscillates or Has a Shimmy
88012 AUG 94 Tools - Exacta Code Key Cutter
88023 DEC 93 Battery - Testing Procedure
ATRATB200 DEC 93 A/T - Starts In Wrong Gear/No Reverse
ATRATB191 OCT 93 A/T - Failsafe Modes
93010 FEB 93 Brake - Rear Caliper Rattle
91019 FEB 93 Emissions - Label Replacement Information
92041 NOV 92 Engine - Vehicle Fails State I/M Emission Test
92040 NOV 92 Tools - Crankshaft Pulley Holder
87006 OCT 92 PDI - Shipping Wax Removal Update
ATRATB132 SEP 92 A/T - Intermittent Electrical Problems
ATRATB125 AUG 92 A/T - Bind-Up In 4th Gear
ATRATB116 JUN 92 A/T - Noise Going Into or Out Of Reverse
SN920505 MAY 92 A/C - Odors From Vents
91029 APR 92 Drive Axles - Clicking Noise While Turning
87014 MAR 92 Radio - Out-of-Warranty Audio Component Repair
SN920301 MAR 92 Parasitic Draw - Test Clarifications
SN920205 FEB 92 Fuel/Emission Notes
92001 JAN 92 Engine - Charging System Testing
ATRATB090 JAN 92 A/T - 4 Speed Pressure Specifications
90014R DEC 91 A/T - Transmission Remanufacturing Program
SN911206 DEC 91 Nose Mask - May Cloud Paint
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
ATRATB069B SEP 91 A/T - 4 Speed Identification
ATRATB068 SEP 91 A/T - Computer Diagnostics
91019 JUN 91 Emissions - Underhood Label Replacement Information
88009 APR 91 Service Bulletin Index Update
90007 APR 91 Service Supplies and Publications
89030 MAR 91 Radio - C.D. Player Exchange Program
89004 FEB 91 Special Tools - Equipment, and Service Manual
86027 DEC 90 Tools - Engine Stand and Adapter Information
90037 DEC 90 Tools - Instructions For New Ball Joint Tool
89029 OCT 90 Radio - Exchange Program
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
90028 SEP 90 Windows - Markings Under Certain Lighting Conditions
90022 AUG 90 Tools - Anti-Lock Brake Checker Repair
90017 AUG 90 Suspension - Squeaking Noise From the Rear Trailing Arm
SN900805 AUG 90 Cigarette Lighter - Switching Precautions
SN900806 AUG 90 Radio - Noise/Interference Service Tip
SN900706 JUL 90 Cassette Player - Clean Light Resetting
MEMO0790 JUL 90 Muffler - Revised Warranty
SN900705 JUL 90 Recycled R12 - Storage Tips
SN900603 JUN 90 R12 Refrigerant - Recovery/Recycling Update
SN900501 MAY 90 Oil Pan Drain Plug Hole - Thread Repair
90011 APR 90 PDI - Correcting Off-Center Steering Wheel
MEMO042790 APR 90 Replacement Battery - Limited Warranty
MEMO040690A APR 90 Replacement Parts - Warranty Extension
MEMO040690 APR 90 Security Systems - Warranty Extension
89032 MAR 90 Paint Codes
MEMO030990 MAR 90 Warranty - Claim Coding Errors
SN900301 MAR 90 Luggage Divider Latch - Rattles
SN900304 MAR 90 Water Pump - Coolant Weepage
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
89037 NOV 89 Battery - Testing Equipment
MEMO1089 OCT 89 Paint - Damaged Vehicle Repair Procedure
MEMO1089 OCT 89 Warranty Parts - Return By Federal Express Airbill
ATRATB8930 OCT 89 A/T - Math Part II
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
MEMO0889 AUG 89 Body and Frame - Rustproofing
89008 FEB 89 Tools - Check Mainshaft End Play
88036 DEC 88 Paint - PDI Inspection
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Default Re: seatbelt recall on honda's (Home Skillet)
i think any, but mines a 90HB
Old Jul 15, 2003 | 09:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">For what years?</TD></TR></TABLE>
Well I know they were recalled for a couple of years but, if your seatbelts or anything else that is safety related mess up, I'm pretty sure they have to fix it for free.
Old Jul 15, 2003 | 10:06 AM
Blaze45's Avatar
Brrraaaap!
Can I have just the recall list for a 91 CRX DX? That would be great!
tia
Blaze
Old Jul 15, 2003 | 11:44 AM
crxchris's Avatar
where can u find recalls ?
Old Jul 15, 2003 | 12:39 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (crxchris)
http://www.alldata.com/recalls/index.html
Old Jul 15, 2003 | 12:54 PM
camera obscura's Avatar
Default Re: (88DXCRX)
I have a '90 Civic sedan DX with automatic seatbelts. All of a sudden, the seatbelt motor stopped working. The belts would go forward, but not back. I took it to the dealer and got it fixed for free. They tried to charge me like $600 for it, but I argued a bit, telling them it was a recall and that its a safety issue and they did it for free. Just don't mess with the belts yourself. They'll check to see if you messed them up yourself trying to fix them.
Old Jul 15, 2003 | 07:33 PM
seekerONE's Avatar
listen up...i work at a dealer and have done so since 89 so i have a clue as to what i am saying.
first...the "recall" concerning the seatbelts was for inspection of the front buckles(specifically the Takata manufactured) for cracks. if no cracks were found then "guide plates" were attached to the buckle to assist the proper insertion angle but if cracks were found then both front buckles were replaced.
second, concerning the lifetime warranty on the seatbelt system. if the belts do not retract, then the first thing we do is inspect the retractor to see if the belt is twisted(common) or if the upper guide is contaminated with dirt and gunk build up(even more common). only if there is a mechanical defect in the retractor would the retractor be replaced. i clean upper guides for slow retracting belts just about everyday.
third, about those annoying automatic belts. yep those are covered under the warranty when they stop working. i have replaced control units and motor assemblies on these many times but the most probable failure of these systems(on the civic four door and wagon) is corrosion on the postitve battery terminal. this is where the auto belt motor fuses are and i have seen the postive terminal corrode the small fuse assembly right off...this is not covered under warranty but is easily fixed with a pair of inline fuse holders.
any questions?
Old Jul 15, 2003 | 07:40 PM
jaydm98's Avatar
Default Re: (seekerONE)
i have a 88 crx si, it did not retract.....so i cut it out......... because it was hitting the paint......could the dealer still replace it?
Old Jul 15, 2003 | 07:56 PM
seekerONE's Avatar
Default Re: (slopokb16crx)
if you cut it out then it is unlikely that the dealer will cover it. as i said most of the time a "broken" seatbelt isn't actually defective. but you can always try.
Old Jul 15, 2003 | 08:16 PM
jaydm98's Avatar
alright ill try the dealer, thanks for the replies.
Old Jul 15, 2003 | 08:18 PM
camboMONK's Avatar
seatbelts are lifetime warranty product. i just got mine replace for 89 crx si from Honda for free. Any Honda dealer should do it for you no question ask. All you have to do is ask.
Old Jul 15, 2003 | 08:27 PM
jaydm98's Avatar
Default Re: (camboMONK)
what happen to your seatbelts? were they cut or anything?
BB1LOViN
Feb 1, 2025 07:36 AM
RichmanA2
Mar 12, 2012 10:32 PM
alacard
16
Nov 4, 2008 07:45 AM
Demonis
Dec 19, 2007 12:02 PM
speedtrash2
Feb 16, 2007 08:46 AM
