How to change a d16a6 timing belt?
I have searched how to do this plenty of times but I dont understand part of it. After I get the crank and cam shaft both to top dead center, I dont under stand when it says rotate the crank 3 teeth counter clockwise. Could someone go into detail on how to do this and what is means? Thanks.
Re: How to change a d16a6 timing belt?
This part is done with the new timing belt already on. Its for adjusting the tensioner.
You put your ratchet with 17mm socket on the crank pulley and turn the crank three teeth (of the camshaft pulley) counter clockwise.
Then you tighten the tensioner bolt.
DO IT ON ALL FOURS
^^^ That and be sure to STOP if anything binds! Triple check everything if you aren't sure of yourself. These are interference engines and NOT something you want to do "close" to correct.
Keyboard Humorist
You have already set the timing and put the belt on.
Then you crank 3+ teeth to remove all the slack out of the front side of the belt.
The slack will be on the back side of the belt where the tensioner can do it's job and remove the slack.
I understand now. But just so I dont make any mistakes, The belt shouldnt come off the crank or cam gear when I turn the crank 3 teeth, And also 3 teeth is just sorta a random number to turn the crank to take the slack out of the front side of the belt, correct? These might be some obvious questions but I would rather be safe than sorry for not asking.
DO IT ON ALL FOURS
You could completely rotate the engine by 12,680,731,432.4298 teeth if you wanted to... It doesn't matter - really you could potentially do it less than 3 teeth. The whole purpose is like mentioned afore and to be sure the tensioner is set properly by rotating the engine. Just do what the manual says - if you think about it - it's common sense.
Thanks everyone for the replies. I do understand how to do it now. THe whole 3 teeth thing for adjusting the tensor kinda threw me off but i realize its just to adjust the tensor now.
get a factory service manual. their cheap on ebay. you'll never have another question again. or download the one for a 91 crx off this page. it has everything. get the one thats 307 mb. http://hondatech.info/downloads/Auto/Manuals/CRX/
Actually you shouldn't turn it more then 3 teeth before you torque the tensioner because if you turn it more then it will actually not be tensioned enough(same if you only turn it 1 tooth). When you turn it 3 teeth keep your hand on the wrench turning the crank to keep tension on it (helps to have an extra hand). Then just turn the crank around a couple times, put it back to TDC and see if everything is still correct.
DO IT ON ALL FOURS
1320london
07-29-2017 02:55 AM
