itr rear swaybar on 91 si?
I have itr rear lca's and they bolted right up with itr shocks and springs.
What will I need to fit the itr rear swaybar?
Former Moderator
Re: itr rear swaybar on 91 si? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">Nobody's tried it? </TD></TR></TABLE>
Ken, I think you're the first to do a LOT of **** on EFs.
I know that the rear swaybar mounts on the Ef are completely different from any EG+Civics or Integras. They are L-shaped brackets that bolt on, and there's no real mounting points on the rear subframe like the EG+Civic and Integra.
Have you tried mocking up mount holes in the rear subframe by holding the ITR rear sway up to it?
Re: itr rear swaybar on 91 si? (B18C5-EH2)
I've only eyeballed it thus far b/c I won't have the itr swaybar ready to install until I get my mugen swaybar on the itr.
In the meantime, I was hoping someone else had done it.
I'm continually surprised how many components simply swap over and bolt right up.....
Like you said though, the mounting will need to be fabricated somehow I'd imagine. I would need to possibly reinforce the rear subframe by welding on some plates, then do the whole mounting point thing.....
Hopefully I'll get it all worked out in time for autox season.....
