89 civic automatic dpfi to mpfi help please???
My friend switched his 89 automatic 4 door civic from dpfi to mpfi he use a d16z6 head and he bought the ps9 computer because it being automatic. it is flashing code 20 witch is electronic load dector or something well if u turn the car off the code still flashes and the battery light and oil light are staying on what is the prob is the wiring or what????
Crazy Honda Guy
your going to have some problems as the mpfi engine came from the SI which had only manual tranny ecu's.
You maybe be able tosolve your problem by doing an OBD1 conversion as the newer d series engines came with mpfi and automatic setups.
Keyboard Humorist
Re: 89 civic automatic dpfi to mpfi help please??? (onefastcrx88)
Double check your wiring and make sure that you really have a PS9. There is no reason that ECU shouldn't be working. Did he also wire in a VTEC controller to activate VTEC? If so, check that wiring too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote"> as the mpfi engine came from the SI which had only manual tranny ecu's</TD></TR></TABLE>
That's not true. The PS9 is from the EX sedan which uses the same motor as the Si, but was offered with an auto tranny.
Re: 89 civic automatic dpfi to mpfi help please??? (4drEF)
hey guys nah i got the ps9 and i have checked my wiring by four diffrent webpages that i have gotten off of here and i am jsut not finding anything wrong with it but i am not getting any spark and i am geting a code 20 well the motoris supposed to run with an si ecu (5-speed) but it will not move due to it being a automatic but it wont even run with that and i am getting the same code i did some searching on here last night and found a trouble shooting flowchart for the code 20 but i dont know much about reading a multi meter but i have one that i got from my g/fs dad. so if anyone can tell me how to set it up so i can troubleshoot the code 20 that would be great also
Keyboard Humorist
Re: 89 civic automatic dpfi to mpfi help please??? (onefaazztcrx)
did you just say that your motor runs with the Si ECU and not with the PS9?
Are you sure the PS9 is ok? Can you check it in another car? (You can plug in into a manual car and it will run the engine, but will obviously throw a code for the lack of an auto tranny.)
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">Double check your wiring and make sure that you really have a PS9. There is no reason that ECU shouldn't be working. Did he also wire in a VTEC controller to activate VTEC? If so, check that wiring too.
That's not true. The PS9 is from the EX sedan which uses the same motor as the Si, but was offered with an auto tranny.</TD></TR></TABLE>
Sorry, my bad, we don't have that here in Canada, i forgot about those EX models. Automatic ecu's and trannies, i've never seen one before.
Re: 89 civic automatic dpfi to mpfi help please??? (Deetz)
nah itll just turn over with both and i have tested both computers and there good thats why i am so confusedthanks Jeremy
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefaazztcrx »</TD></TR><TR><TD CLASS="quote">nah itll just turn over with both and i have tested both computers and there good thats why i am so confusedthanks Jeremy</TD></TR></TABLE>
Your mpfi wiring is forked.
check if you used the different pin numbering .
Some people numbr them across in their directions, and some - the other way.
I mean this:
1)
|. . . . . . . . . . 7 5 3 1|
|. . . . . . . . . . 8 6 4 2|
2)
|. . . . . . . 4 .3 . 2 .1.|
|. . . . . . 14 13 12 11|
Possibly whoever wrote the directions used one system, but you read it the other way.
Modified by nikitad at 5:48 AM 4/11/2004
I mean this:
1)
2)
085714accord
10-07-2008 04:31 AM
