Swap problem - Crx b16
Old 05-01-2004, 10:14 PM
souljad9's Avatar
Default Swap problem - Crx b16
Were in the middle of doing my friend's swap, And we've hit a snag. Everything's in, the motor cranks, but doesn't start. We're figuring it's a fuel problem, because when you spray starter fluid in the intake (not my idea), it catches, and will backfire. You can also hear a sort of gurgling noise coming from the fpr. Any Ideas?
Old 05-01-2004, 10:20 PM
goodwinesi's Avatar
Default Re: Swap problem - Crx b16 (souljad9)
Is everything wired up? Plugged in? Is it grounded good?(crucial) Got your plug wires in the right places? Lot of things it could be man.
Old 05-01-2004, 10:59 PM
michael O's Avatar
Default Re: Swap problem - Crx b16 (goodwinesi)
check your wiring. I just got my swap started because I wired the dizzy up wrong.
Old 05-02-2004, 07:36 PM
C-REX 88's Avatar
Ya i would say check the grounds. I had the same problem, no fuel was getting to the fuel rail. Ilooked around and found a ground off. After i connected it it worked fine
Old 05-02-2004, 08:01 PM
0554's Avatar
sounds kinda like the plug wires are on backwards. i donno to hard to say with such little info.
Old 05-02-2004, 08:07 PM
michael O's Avatar
Default Re: (88crex)
my dizzy was wired 180 degrees off and the car still ran when I sprayed starter fluid in it just ran like ****. So I say double, triple, quadruple check wiring.
crxracer2006
09-22-2005 11:46 AM
CHAPY
04-15-2005 09:03 AM
91_civicsi
17
06-11-2004 08:26 PM
90_Civic_Hatch
10
08-09-2002 11:05 AM
Hayate42
04-10-2002 12:56 PM
Quick Reply: Swap problem - Crx b16
