crazy idle
Old 06-24-2004, 09:58 AM
messeduprex's Avatar
Default crazy idle
ok my car just started doing this it likes to idle a 100 rpm not rough but low once and a while it wil stall out when i come to a stop almost like an eclipse with a blow off valve i have no clue what it is i checked all the vacum hoses no leaks anywhere new timing belt distributor, plugs(denso iridum),ngk wires msd sci ignition w blaster coil
Old 06-24-2004, 10:13 AM
crx_88_si's Avatar
This was happening b4 u changed the timing belt?..
Try turning the idle screw. While the car is running unplug the IACV the car should stall out completely or almost die..then report back.
crx_88_si's Avatar
Default Re: (crx_88_si)
also go read this thread on HMT, great idle troubleshootin tips.
http://www.homemadeturbo.com/f...12879
JKing106
04-13-2013 05:51 PM
thunderlips
10-17-2008 03:19 PM
dc2LS
01-18-2008 06:06 PM
civickiller
02-15-2007 12:38 AM
guywitaDA
07-27-2005 01:15 PM
Quick Reply: crazy idle
