88 crx rear LCA's? what aftermarket ones will fit?
What models will fit?
There is a local company selling megan racing ones for cheap and i wanna pick a set up for when i put in the new suspension setup.
btw - its for an 88 crx dx.
thanks.
thanks.
Re: 88 crx rear LCA's? what aftermarket ones will fit? (ZC88CRX)
i know the SRR LCAs fit in the ef hatch (LCA for the EG) so they should fit or ur rex.i m getting the srrs for 185 never heard or megan? prob cheap crap
megan sucks...
function7 makes them for the 88 crx/civic...i personally got brand new honda lcas...
Re: 88 crx rear LCA's? what aftermarket ones will fit? (spaceman)
i think its http://hybridgarage.com are the ones who make it...i forget...
Re: 88 crx rear LCA's? what aftermarket ones will fit? (91EFHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EFHatch »</TD></TR><TR><TD CLASS="quote">those look like **** to me </TD></TR></TABLE>
and looks have what to do with function...
Re: 88 crx rear LCA's? what aftermarket ones will fit? (hOnDadiCt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOnDadiCt »</TD></TR><TR><TD CLASS="quote">SRR LCAs </TD></TR></TABLE>
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">
and looks have what to do with function... </TD></TR></TABLE>
very correct my friend
no one will even see them and unless u road race the car u won't feel a difference
Re: 88 crx rear LCA's? what aftermarket ones will fit? (krazie1)
srr's are nice but its too bad they don't make them for an 88.
as almost always the answer is at your local honda/acura dealership
TYPE-R lca's all the way
Re: 88 crx rear LCA's? what aftermarket ones will fit? (racerxb18b)
bump, I need something for an 88 crx. My rear lca bolts are ******* seized so I need some new ones, dont care if there used or what, as long as they bolt up using the 88 style shocks and come with bolts/bushings
Keyboard Humorist
Re: 88 crx rear LCA's? what aftermarket ones will fit? (Jurassic Four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four »</TD></TR><TR><TD CLASS="quote">DA rear assembly </TD></TR></TABLE>
Wrong shock mount.
Wrong shock mount.
Re: 88 crx rear LCA's? what aftermarket ones will fit? (FrankencrxBHAM)
i need the website for megan racing, ssr, and also onmipower now carries them but i dont know if its for the 88.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">still what ones are for the 88. </TD></TR></TABLE>
It's already been answered: The Integra Type R rear LCAs are the same as the '88 CRX. They're designed with a little bit of toe-correction built into them (they flex just a bit under load, and I believe the outside wheel in a turn toes out a bit), so they help the car rotate. American drivers had problems with this in some situations, because off-throttle oversteer became an issue with these cars for some stupid people. The US got the redesigned rear suspension for '89 and after, while the rest of the world got better-handling CRXs.
I miss my '88 Si...
Mike
I miss my '88 Si...
Mike
Re: 88 crx rear LCA's? what aftermarket ones will fit? (Kwicko)
ok wow, you people arent getting it, then who makes and after market one for the type r, cause im not paying the money for true type r ****. also would they fit without having to change ANYTHING.
mr. Grind
06-30-2004 12:08 PM
