CODE 5 PROBLEMS
Old Aug 2, 2004 | 02:11 PM
barry11j's Avatar
Default CODE 5 PROBLEMS
i just did a b16 swap in my 91 crx si....the ecu keeps throwing code 5.....i know that it is the map sensor, but code 3 means that it is a bad map sensor, and code 5 in a bad vaccum....is this correct....i have 1 hose from the map sensor that i "plugged up" with a screw....what do i need 2 do..?
Old Aug 2, 2004 | 02:21 PM
barry11j's Avatar
Default Re: CODE 5 PROBLEMS (barry11j)
any 1 ?
Old Aug 2, 2004 | 03:21 PM
wpgcivic's Avatar
take a pic of it and ill tell you, i just fixed that issue
Old Aug 3, 2004 | 01:14 PM
barry11j's Avatar
Default Re: (wpgcivic)
it is the last tube running into the map sensor ( on the firewall) it looks like a film canaster....i have no cam to take a pix...sorry
Old Aug 3, 2004 | 06:44 PM
wpgcivic's Avatar
ok do you have a vacuum line running from the map to the t-body? there should be one there, i donno about where you live but here in canada we have no emmisions , so i dont even have a charcol canister
Old Aug 3, 2004 | 08:21 PM
jlicrx's Avatar
Default Re: (barry11j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barry11j &raquo;</TD></TR><TR><TD CLASS="quote">it is the last tube running into the map sensor ( on the firewall) it looks like a film canaster....i have no cam to take a pix...sorry</TD></TR></TABLE>
the MAP sensor doesn't look like a film cannister - that is probably the purge cut-off solenoid valve, which is right beside the MAP - MAP has one vacuum hose from throttle body (vacuum port nearest front of car, next to port with red braided cloth covered hose to the purge cannister)
Old Aug 4, 2004 | 09:45 AM
barry11j's Avatar
Default Re: (jlicrx)
i know that it isnt part of the map sensor, but the vac hose that it runs to i cannot find where it goes...in the county i live in we do not have emmissions either !!!!!!
eggie75
Apr 7, 2008 01:40 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
Sci_v_icI
Apr 5, 2006 10:44 AM
DAMCOOLDAV
Sep 12, 2003 02:05 PM
Frosty_spl
Feb 12, 2002 02:06 PM
