Single VTEC swap dizzy
i got a question for people who have swapped in a sohc vtec into crx, what dizzy did you use, and were the're any problems? i got an Si one in my HF with a d16y8, and somethign's ******* up cause my gas mileage is **** and my power is bogging. anyone had experience with this?
hes not talking about the trannys.....its most likely the crank angle sensor kept screwing up on mine so you have to take apart the dizzy and loosen this screw at the bottom, dont take it all the way out just loosen it some thats what i had to do.
Re: (Bserieskllr)
did you get check engine light when you're crank angle sensor fucked up? also, im using the 4 spd DX tranny (dont ask, it was an emergency) and i was getting about 27-30 mpg before, i got an Si one i should swap tonight, but i doubt the gas mileage will go that low (20-21)
Re: (crx_88_si)
im using a chipped pm6, the chip doesnt affect the fuel too much, juss bumped up the rev limit, i was getting bad mileage on a stock pg7 too that i was running before.
vtecn8ive
09-19-2005 03:43 PM
audioroach
02-23-2003 08:54 PM
