a6 injectors in JDM D15B sohc vtec rail?
Old 03-24-2005, 12:40 PM
psicrxsi's Avatar
Default a6 injectors in JDM D15B sohc vtec rail?
will this work? im working on swapping the engine and i want to use the obd0 fuel injectors...mainly for the resistor box cause im gonna turbo it later ill be converting to obd1 using a conv harness and a p28ecu, but i want to use the obd0 fuel injectors on the obd1 fuel rail...will that work or will i have to use a d16a6 fuel rail? im converting my dx to si wiring so i dont have a d16a6 fuel rail to start off with. i can buy fuel injectors on ebay for cheap and i just want to know if they will fit on the jdm d15b fuel rail? THX
Old 03-24-2005, 02:21 PM
CRXVTEC69's Avatar
Default Re: a6 injectors in JDM D15B sohc vtec rail? (psicrxsi)
yes you will need to use the D16A6 injectors and FPR (fuel pressure regulator) trust me you will see why. I did this on my D15B VTEC swap last weekend. Tomorrow night I am hooking up the conversion harness to plug in my P08 ECU woohoo
Old 03-24-2005, 04:02 PM
psicrxsi's Avatar
Default Re: a6 injectors in JDM D15B sohc vtec rail? (CRXVTEC69)
the a6 pressure regulator? dont i have to use the vtec one since i know the vtec engine runs at a diff fuel pressure? so i can use the a6 fuel injectors on the jdm d15b fuel rail right?
slideintegra08
08-29-2010 11:48 AM
Jenkinsal2
12-29-2009 09:48 AM
B18c1vicrx
04-08-2008 06:21 PM
Shadow Templar
01-30-2004 08:25 PM
B18C-RnVA
04-21-2002 09:13 PM
Quick Reply: a6 injectors in JDM D15B sohc vtec rail?
