What should I do with this crappy engine .... (pics)
89 Civic dx Hatch --- what should I upgrade this too... Its an Automatic with STOCK everything.
what kinda engine is one step up and easy to put in ?
Re: (tallguy)
what should you do with it? nothing
There's no way to build a D15 block and get respectable power out of it compared to building a D16. Exception is the D15B however.
Re: What should I do with this crappy engine .... (sxeonerX)
ya im not looking for a really expensive engine or to get alot of power out of it... i just want something brand new that doesn't have 240,000+ miles on it like that one does.
so .. b16 .. d15b .. dohc zc ... what would be the cheaper and / or easier way to go
Re: What should I do with this crappy engine .... (douglaslovin)
Ok ok ... since i don't know much about engines haha. would either of these work
http://www.hmotorsonline.com/s...30019
http://www.hmotorsonline.com/s...30021
http://www.hmotorsonline.com/s...30018
and would any Mods need to be made on any of those to drop it in a 89 civic dx Automatic
Re: What should I do with this crappy engine .... (sirq2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u »</TD></TR><TR><TD CLASS="quote">you can give it to me when you do a swap... </TD></TR></TABLE>
help me put it in.. and its yours.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douglaslovin »</TD></TR><TR><TD CLASS="quote">
help me put it in.. and its yours.</TD></TR></TABLE>
Re: What should I do with this crappy engine .... (Thrillhouse)
been doin some searching
will i need the MPFI swap for an auto... on all 3 of those engines i listed.. and are all 3 of those engines all able to be put in my car?
as far as the mpfi auto swap i found this thread - https://honda-tech.com/zerothread?id=411366
all that correct? i need all the stuff from an auto 90-91 ex ?
You should get a jdm d15b vtec...be a little different. I think the DOHC zc's kinda suck. The parts have always seemed frustrating to me and there practically no aftermarket stuff for the DOHC zc
Re: What should I do with this crappy engine .... (pogiTSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI »</TD></TR><TR><TD CLASS="quote">Drive it till it dies, THEN swap the motor, unless your REALLY hard up for power.</TD></TR></TABLE>
thats prolly your best bet. if you want to mod now then nuy another block and build one up out side the car first then swap when the current one pukes. or shoot it with a 100 shot when your ready to swap
Re: What should I do with this crappy engine .... (93formula)
AT to MT swaps arent too expensive #1. And as long as you have the right harness you can put any B series into your car. ( and mounts of course) Go to your local junk yard and find a set of pedals, and a trans cable, and your golden. Linkage should come with the swap.
[QUOTE=douglaslovin]Ok ok ... since i don't know much about engines haha. would either of these work
the b16a 88-91 SIR is the best one of those three. you need motor mounts and a some other ****. check for a list of what U need
http://www.hasport.com
No way; he'll be an old man before that D15 dies, unless it's not maintained at all. It's a Honda after all, built to last!
Re: What should I do with this crappy engine .... (Oyvind Ryeng)
the b16 is probably out of your budget, the cost you spend to swap in a stock one you can have a sohc or dohc zc swap w/a lil mods for equal or less i'm sure. good luck.
Any D16/ZC would net a GREAT overall power improvement over the current DPFI D15.
No need to go B16, especially if you're low on $$$ and this is your first swap.
B16 AUTO sucks *****!!!
what's the use!!!!!!
Needs to be About 20% Cooler
1 Post
Re: What should I do with this crappy engine .... (HumanResource)
he needs to put the old motor in a custom bult gokart that would have a nice power to weght ratio as soon as i learn how to weld thats what i will do
