starter problems
starter problems
maybe someone can help me with this.. my car would not start one day so i replaced my started thinking i needed a new one, bc my battery is fine and i replaced my alternator not too long ago, plus i could push start my car. yet, i have the same problem with the new starter.. could it be possible that the new (used from H motors) starter is bad too, or do have other problems?
Re: starter problems (raymas8)
Does it turn over at all?
Does it sound like it will turn over if you hold the key in the start position for a few seconds, but the moment you let go it dies?
Does the check engine light come on in the "on" position?
Does the main relay click and do you hear your fuel pump prime up when you turn the key on?
Answer these questions and we may have a solution for you.
Re: starter problems (crxtreme89h)
OLDER OBD-0 CARS ONE SUGGESTION................CHECK UR DIZZY.............HAD A PROBLEM WITH IT IN EACH HATCH AND CRX THAT I HAVE OWNED.............. MIGHT NEED A NEW COIL OR JUST GO AHEAD AND REPLACE THE WHOLE DISTRIBUTOR
Re: starter problems (b18_crx)
ok here it is.. when i turn the key i hear a clicking sound and no it doesnt really seem like is would turn over if i held the key on. i replaced the main relay not too long ago and i hear the fuel pump turn on. I just dont get it it ran just fine before.. and the engine will run if push started..
connections are good. no more clicking sounds when i turn the key, but its not the battery coz i tried jumping it with another car.. no luck
Modified by raymas8 at 6:39 PM 5/17/2005
bro its ur starter, maybe its grounded out somewhere its suppose to be grounded out at, im havin the same problem did u ever get it fixed? and wat made it work?
junya16
02-26-2003 08:31 AM
