Differences in ECU's
Old Aug 14, 2005 | 03:05 PM
TwztdSi's Avatar
Default How to tell difference between manual and auto ecu.....HELP
Is there a way I can tell the difference between an auto and manual ecu just by reading the numbers on them?
Modified by TwztdSi at 7:11 PM 8/14/2005
Old Aug 14, 2005 | 05:44 PM
TwztdSi's Avatar
Default Re: Differences in ECU's (TwztdSi)
anyone?
Old Aug 14, 2005 | 05:47 PM
DieMaster's Avatar
Needs to be About 20% Cooler
i dont remimber exatly but theres anumber after the code PM6-L005 it's eather L or A (emmisions?) and if it ends in5 it's a manual and 0 or even number is auto. somthing like that. i know i'm wrong but i got the idea.
Old Aug 14, 2005 | 06:07 PM
TwztdSi's Avatar
Default Re: Differences in ECU's (DieMaster)
Well there are two different ecu's I"m looking at on ebay. the numbers are..... 37820-PG7-A131..... and ..... 37820-PG7-A022 I'm looking for an Auto PG7 or a PS9
Old Aug 14, 2005 | 07:11 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwztdSi &raquo;</TD></TR><TR><TD CLASS="quote">Well there are two different ecu's I"m looking at on ebay. the numbers are..... 37820-PG7-A131..... and ..... 37820-PG7-A022 I'm looking for an Auto PG7 or a PS9</TD></TR></TABLE>
the A022 is manual - the A131 is automatic
A0## or L0## = manual
A1## or L1## = automatic
Old Aug 15, 2005 | 05:19 AM
TwztdSi's Avatar
Default Re: Differences in ECU's (jlicrx)
Thanks for the help and I hope you are right cause I just bid on it...lol
Old Aug 15, 2005 | 05:28 AM
Kryogen's Avatar
hes right, Hes on another board I frequent....He is VERY informative..
Old Aug 15, 2005 | 08:17 AM
b18_crx's Avatar
Default Re: (Kryogen)
Old Aug 15, 2005 | 09:10 AM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
On my PM6 and P28 ecus, there are only 2 # spots after the 'L' or 'A'. What I am saying is that there it looks like this: A##; instead of A0##.
On my recently departed PM6 ecu it said: PM6 - L09. There is no number after the 9. I also remember reading that the if the two numbers behind the 'L' or 'A', if it is under 50, its from a manual, if it is above 50, its from an automatic. Meaning L09 is manual and L53 is automatic.
Also, I believe that all L0## or L## (whichever) ecus are from california sold cars and A0## or A## are from the rest 49 states.
Old Aug 15, 2005 | 10:06 AM
DieMaster's Avatar
Default Re: Differences in ECU's (Mach69)
i knew i was close. i needed this too when i do my MPFI swap, will i need a CA PS9?
Old Aug 15, 2005 | 07:58 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">I also remember reading that the if the two numbers behind the 'L' or 'A', if it is under 50, its from a manual, if it is above 50, its from an automatic. Meaning L09 is manual and L53 is automatic.</TD></TR></TABLE>
that is not correct - the number indicating whether it is automatic or manual is the first number after the letter - 0=manual 1=automatic, for most ECUs - however, as with everything Honda does, there are exceptions - for instance: 86-87 Integra ECUs don't have a letter after PG7 - they have 66 for manual and 67 for automatic - some ECUs have 2 numbers after the A0, L0, A1 or L1 and some have only one - ECUs from cars originally sold in Calif do have the letter 'L' while everywhere else it is 'A'
Old Aug 15, 2005 | 08:02 PM
Mach69's Avatar
that is not correct - the number indicating whether it is automatic or manual is the first number after the letter - 0=manual 1=automatic, for most ECUs - however, as with everything Honda does, there are exceptions - for instance: 86-87 Integra ECUs don't have a letter after PG7 - they have 66 for manual and 67 for automatic - some ECUs have 2 numbers after the A0, L0, A1 or L1 and some have only one - ECUs from cars originally sold in Calif do have the letter 'L' while everywhere else it is 'A' </TD></TR></TABLE>
Well, wrong again. Atleast I learn something evertime I'm wrong.
And damn, I was right on only one part again with the 'L's.
tuoniz
Oct 28, 2005 01:22 PM
verbol assassin
Oct 18, 2005 09:54 PM
tmihok
Jun 17, 2004 04:31 AM
Tad
20
Jun 5, 2004 01:11 PM
AMChev
May 20, 2002 10:29 AM
