My new bottom end ... Do i need to break in?
b18a block
Scat H beam Rods
Arp Rod bolts
Mahle 9:1 compression pistons (w/ Heat and friction protection)
b16 water pump
b16 oil pump
New Gsr Timing Belt
Acl Race Rod Bearings
Unorthadox Racing Crankshaft Pully
This will be mated to a b16 j1 tranny, b16 vtec head using arp headstuds...but my question is...after i put this together on monday or tuesday and have it in the car ....do i need to brake it in?? Because im putting it together and breaking it in all motor...then next week i will but the turbo back on...only differnce is a bigger turbo and bigger FMIC then my last setup...so let me know what you guys think
Scat H beam Rods
Arp Rod bolts
b16 water pump
b16 oil pump
New Gsr Timing Belt
Re: My new bottom end ... Do i need to break in? (hotimportcrx)
Yes you will need to break it in to seat the rings. You are having the bores honed before installing new pistons right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx »</TD></TR><TR><TD CLASS="quote">u mean am i having the block honed before installation?? if you mean that yeah </TD></TR></TABLE>
Yeah you should have the block honed....so therefore you need to break the engine in to properly seat the piston rings.
Re: My new bottom end ... Do i need to break in? (91civic)
oooooooooooo yea the block is gonna be honed....but how do i break it in...drive it for 500 miles under 3k
Give me a List of EVERYTHING that i will need when rebuilding the bottom end of my b16, including st
B16Civic93
05-21-2005 01:17 PM
