pr4?
Re: pr4? (superbeastcrx)
Yes the ecu has a revlimiter which I think is around 7200....not sure though. Yes when you have the ecu chipped you can specify to take it out. Only good reason to take it out is when you are making power above the limiter
Yes, all stock ecus have a rev limiter. The PR4 is from the Integra LS, so the limiter is around 7400rpm I think, not 100% sure. Removing the rev limiter isn't a great idea, as one missed shift can be the end of your motor. It's better to just raise it up so you have a safety net. Prices vary, but it comes down to you'll need to have the ecu chipped and a new rom made and put in.
