need help
Re: need help (hugo7)
you could have a short somewhere in the wiring that is fused at the same point as the dash wiring....thats what happened to me....i put in my new dash and it wouldnt light up,,,,,but there was no deck in my car so when i was under there and moved a few wires one (stero related wire) stuck to the metal mounting ......which is why the fuse blew...check all fuses....your signals should work and high beem indicator...but lights wont correct....your parking lights probably dont work either right?....if not then its most likely just a shot dash u put in,.....or you didnt plug everything in 100% ....check fuses....
ilovemydc5
05-22-2007 12:45 PM
plusONE DC2
12-10-2004 05:10 PM
