Car no run!!! - Honda-Tech - Honda Forum Discussion
Car no run!!!
Old 11-05-2005, 07:33 PM   #1
MrPotatoeHead's Avatar
Default Car no run!!!
Ok well I was driving my car today and stop at Murrys. Go in come out and go to start my car. Just cranks. Turn key off and turn on(listen for fuel pump) nothing. Lift carpet and look to see if te light is on...NOPE....Check ecu fues and its all good. Listen for main relay to click and it does....When I crank it seems like im getting no spark...And when it cranks it goes duh duh then cranks...Its like in the middle of the crank it tries to start then nothing but spin....
MrPotatoeHead is offline   Reply With Quote
Old 11-05-2005, 07:55 PM   #2
Crx Jimmy's Avatar
Default Re: Car no run!!! (MrPotatoeHead)
spray some starting fluid in the throttle body, if it starts then for a couple secs you know its a fuel problem
Crx Jimmy is offline   Reply With Quote
Old 11-05-2005, 08:29 PM   #3
Default Re: Car no run!!! (Crx Jimmy)
up
Old 11-05-2005, 10:19 PM   #4
sidewayz32's Avatar
you need to verify that you are getting spark and fuel.
right way: spark tester or timing light hooked up while cranking
fuel pressure gauge
easy way: pull a plug and crank with plug exposed ...watch for spark
crank engine then pull plug, see if it is wet with fuel
if you aren't getting spark, i'd start with checking the ignition switch for continuity, look in a service manual for which plugs to check.
if you aren't getting fuel, i'd start by ohming out the fuel pump and checking for leaks. you can also see if the injectors are firing by placing the end of a flathead screwdriver on the body of the injector itself. put your ear on the end of the screwdriver with the handle. you can hear a tap every time the injector fires. you will also be able to tell how strong or weak the injector is.
sidewayz32 is offline   Reply With Quote
Old 11-05-2005, 10:48 PM   #5
schwingding's Avatar
Default Re: Car no run!!! (sidewayz32)
the main relay actually has 2 relays in it mine wasnt workign right and i was hearing one of them click but the one for the fuel pump wasnt clicking so it didnt send power to the pump or injectors try jumping the #1 and #7 i believe they are they white/yellow wire and the black/ yellow wire to get ypur fuel pimp to run
schwingding is offline   Reply With Quote
Old 11-06-2005, 04:13 PM   #6
RapeV-8's Avatar
main relay!!! or check ur dizzy!
i can help you out, just call me.. i got a dizzy, main relay,ecu, etc
RapeV-8 is offline   Reply With Quote
Old 11-06-2005, 06:45 PM   #7
Default Re: (igotcrx)
Fixed it was the rotor screw...It fell out....
weird crank but no start- boosted gsr on crome t3h jam Tech / Misc 3 06-13-2015 03:39 PM
car not cranking problem (eg coupe b16) hmongxcuz Tech / Misc 3 01-27-2011 11:19 AM
Starting problems in the morning thusee Honda Accord (1990 - 2002) 6 10-22-2009 05:40 AM
92 Accord EX start problems FIDIRO Honda Accord (1990 - 2002) 15 07-06-2006 05:34 PM
2 kills in a night 1quickcrx Kill Stories 20 01-28-2005 06:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
