light switch arm and wiper switch arm install dificulty
how hard is it to put one of these in because mine is old and sometimes even thought you click it the low beams wont come one. so i think the swith is worn out. so i plan to buy a used one on ebay. just want to know if its ridculosly hard to get the old one out and put the new one in.
http://cgi.ebay.com/ebaymotors...ZWDVW
Re: light switch arm and wiper switch arm install dificulty (hondatuner20)
It's not hard, I did mine a few months back. Actually I disassembled the piece you linked to and just swapped the wiper switch. If you do the whole thing at once it's a piece of cake.
And I'm no mechanical genius. Just be careful removing the plastic trim pieces from the column.....don't overlook any screws
Location: Land of the free, whoever told you that is your enemy
Remove the steering wheel 19mm, and the collum shroud screws, then there are a few screws that hold it on, unplug all the wires, and pull it off, reassemble in opposite order.
danomatic93
52
11-16-2018 02:53 PM
