will b18c swap work on 87 crxsi??
Re: will b18c swap work on 87 crxsi?? (pnoytegn707)
Hasport makes a motor mount kit for B-series swaps into 1G CRXs. But there are still issues that must be dealt with. First of all, these mount kits are made for a cable transmission ONLY. There is no hydraulic conversion kit for this generation of Civics/CRXs. So if you use this kit (or likely any other that is available), you will have to separately source a cable transmission for the job. Secondly, there is the issue of the intake manifold. Now I have heard nothing in stone about this. But everyone suggests that the stock GSR intake manifold WON'T fit. With this said, you will likely have to go to a single runner style manifold such as the Skunk2 manifold. And finally, if you want to run the P72 ECU, a wiring conversion is in order.
Re: will b18c swap work on 87 crxsi?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Hasport makes a motor mount kit for B-series swaps into 1G CRXs. But there are still issues that must be dealt with. First of all, these mount kits are made for a cable transmission ONLY. There is no hydraulic conversion kit for this generation of Civics/CRXs. So if you use this kit (or likely any other that is available), you will have to separately source a cable transmission for the job. Secondly, there is the issue of the intake manifold. Now I have heard nothing in stone about this. But everyone suggests that the stock GSR intake manifold WON'T fit. With this said, you will likely have to go to a single runner style manifold such as the Skunk2 manifold. And finally, if you want to run the P72 ECU, a wiring conversion is in order.</TD></TR></TABLE>
and, you need to swap knuckles/hubs for ones from 86-89 Integra and get Hasport axles and shift linkage
a GSR will not go into a 84-87 CRX without a intake manifold swap, a B16/ITR or aftermarket manifold will be required
and yes you will need to swap to a Bseries Cable tranny, you will need hasport axles, 87 Integra knuckles alot of wiring, and hasport mounts, along with all the little **** that comes up
88-91 CRX with GSR wont be a problem just, mounts, shift linkage, axles and a lil bit of wiring
Re: will b18c swap work on 87 crxsi?? (DEIVIONCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX »</TD></TR><TR><TD CLASS="quote">a GSR will not go into a 84-87 CRX without a intake manifold swap, a B16/ITR or aftermarket manifold will be required</TD></TR></TABLE>
Really?
Modified by sixty-seven point six at 12:22 PM 2/9/2006
Really?
I have an 87' crx si that I would like to put either a b18 or b20 into it, the problem is I am new to it all including these forums. Also I would like to turbocharge whichever I end up putting into it. any ideas on what I need and what I should get?
sorry about posting it here but I just joined and cant make my own thread so I figured I would mooch off someone else trying to do a similar swap
THANKS!!
THANKS!!
beef-cake
02-27-2006 04:42 AM
