Civic starting problems
Ok I have a 1991 Civic hatch. It runs pretty well and strong other than my clutch issue right now. I have noticed that after driving it a short while , let's say 10 minutes. I turn the car off and then I when I go to start it again. it won't It cranks over but it doesn't start for sometime. What is causing this? I replaced the battery recently so I know its nota bad battery. Could a bad rotor and cap cause this? What about a bad clutch?
Thanks again.
Jon
Thanks again.
Jon
Re: Civic starting problems (TeamRedline89Hatch)
I have never tried to look at it. Isn't it right under the floorboard of the front passenger side
Re: Civic starting problems (bonstokLS)
does the fuel pump prime when you turn the ignition to the on position, if not time for a new main relay. they go out all the time on cars of that age.
Re: Civic starting problems (b18ccivics)
I don't have anyone to help me look when I try to start it. Can I see it prime when the ignition is ON?
smbignick
08-18-2013 01:47 PM
