OBD0 vs OBD1 B16a Distributors (Searched)
Old 08-15-2006, 10:32 PM
jedubz's Avatar
Default OBD0 vs OBD1 B16a Distributors (Searched)
Having some leaking from under my distributor (also just recently bought a new cam seal that I plan on installing. When I looked underneath the disty, I noticed I only had it attached from the top bolt. So I'm wondering
Is the OBD0 (B16A SiR) Disty O-Ring and bottom bolts the same as the
OBD1 (SiR2 / del Sol VTEC) B16A's? B/c I think I need to order them!
Old 08-15-2006, 10:56 PM
salman's Avatar
Default Re: OBD0 vs OBD1 B16a Distributors (jedubz)
Yeah, cam seal are same.
Old 08-30-2006, 02:30 PM
jedubz's Avatar
Default Re: OBD0 vs OBD1 B16a Distributors (salman)
I realize the cam seal is the same, but is the distributor O-ring and bottom distributor bolt from an OBD-0 B16 (sir/xsi) the same as an OBD-1 B16 (del sol vtec)? I need to order these parts ASAP!
Old 08-30-2006, 03:14 PM
Brick Top's Avatar
pretty sure the o ring and bolt are the same for both. correct me if im wrong.
Old 09-07-2006, 07:26 PM
jedubz's Avatar
I am looking at a picture of a Del Sol and the disty bolts seem to be place differently. Same with the 2001 Si, does anyone have any pictures up close of the b16 disty on an OBD0 vs 1 or 2?
Old 09-07-2006, 07:28 PM
Crx Jimmy's Avatar
Default Re: (jedubz)
the bolts will work also your old d series bolts are exactly the same. the o-ring is the same
jrmacho22
07-08-2011 02:49 PM
90_hatch_b16
02-27-2008 08:13 PM
DustinRose
02-12-2007 03:18 PM
uberhaulin
11-18-2006 06:48 PM
turboem2
03-17-2004 03:21 PM
Quick Reply: OBD0 vs OBD1 B16a Distributors (Searched)
