HELP!?!?!?!?
HELP!?!?!?!? wheel bearing??
went to go to work today. and i heard sumthing that sounded like something was draging. after work i went out and fixed y exhaust from haning near the resanotor. took for a drive and there's still a noise near the driver side back tire. just wondering what it could be. my thought is a wheel bearing?
help please i think that needs to be fixed lol
Modified by joeny12985 at 6:08 PM 8/28/2006
Re: HELP!?!?!?!? wheel bearing?? (joeny12985)
could be brakes,do you have disk or drum? My rear mud flap use to drag the ground on my old crx.
1 Post
Does the sound increase with speed. A wheel bearing will make a whirling noise that increases with speed.
I would jack up each side and give the wheel a turn and see if it makes the noise, also grab the wheel and try to move it in and out to see if you have any play in the bearing.
Also when the front brakes wear down there is a little metal scraper that makes alot of noise. It is kind of a warning system.
Here's a couple to check out!
when i suspect i bearing, i always isolate the hub by removing the caliper. compare it to the passenger side. if you feel more resisatnce or if it sounds bad then it's a bad bearing. do you see grease/dirt on the cover?
Re: HELP!?!?!?!? wheel bearing?? (eda6)
it's my rear hub and i'm trying to take the one off my parts car first before i break anything on my dd. i need it to go to work and back
Open up your rear drums and inspect them. You could of done what happened to me. You busted a springs on the inside and the rear drum fell apart on the inside. Scratches the **** out of it. Wheel bearings grind when they seize up good. Check the tires from rubbing or anything else interferring with rotating assemblies such as wheels.
