code 20
New User
Re: code 20 (211811518)
Code 20 is ELD..Electronic Load Detector...as long as the car isnt acting up at all i wouldn't be too concerned with it. It wont affect drivability or anything.
Re: code 20 (CanuckCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanuckCRX »</TD></TR><TR><TD CLASS="quote">Code 20 is ELD..Electronic Load Detector...as long as the car isnt acting up at all i wouldn't be too concerned with it. It wont affect drivability or anything.</TD></TR></TABLE>
Um, when the check engine light is on the car is in limp mode, meaning more fuel will be tossed at your engine causing you to run rich, check engine light is never good.
https://honda-tech.com/zerothread?id=1508680
New User
Re: code 20 (90blackcrx)
There is no CEL for the ELD, it is just a soft code, does not effect anything. Trust me, if you know anyone running a JDM ECU in their swap, up here in Canada anyways, the ELD code 20 is there. We dont have ELDs in our cars, just in the US and Japan. I have seen it many times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanuckCRX »</TD></TR><TR><TD CLASS="quote">There is no CEL for the ELD, it is just a soft code, does not effect anything. Trust me, if you know anyone running a JDM ECU in their swap, up here in Canada anyways, the ELD code 20 is there. We dont have ELDs in our cars, just in the US and Japan. I have seen it many times.</TD></TR></TABLE>
I also have ELD Issue in my car, but thing are ok even with it,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 211811518 »</TD></TR><TR><TD CLASS="quote"> flashing 20 times?</TD></TR></TABLE>
The Ecu light Flashes only 2 times for ELD, or to display code 20, your not reading it in the right way,
Stouts 'n' Scotch
Re: code 20 (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman »</TD></TR><TR><TD CLASS="quote">
The Ecu light Flashes only 2 times for ELD, or to display code 20, your not reading it in the right way, </TD></TR></TABLE>
Depends on the ECU, on stock ones for this year range EFs they just blink the number of times for the code. (I believe this is true for all OBD0 systems as well). You're referring to the OBD1 style, where you have short and long blinks.
Re: code 20 (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
You're referring to the OBD1 style, where you have short and long blinks.</TD></TR></TABLE>
obd0 is the same
I'll take your word
obd0 is the same
I'll take your word
Well fellas, I got rid of the code 20!!!!!!!!!!!!, I had almost no ground (extremely high resistance 2.5Mohms) between the battery and chassis. Thanks for all your input
dubnine
06-01-2007 07:00 AM
PINKS
11
07-13-2006 06:00 PM
