1.5L distributor VS 1.6L distributor
Well I have come across a problem. I have 5 D15 heads sitting around and a D16A6 with a knock (head still attached and in great shape). The D16 does not have a distributor.
Distributors I have are.
90 CRX HF distributor (d15b6)
93 Civic EX distributor (d16z6)
I also have OBD0 wiring that will work with the 93 EX distributor. And ofcorse my STD wiring on my 1990 EF STD plugs and plays on the HF distributor. I noticed diffrent part numbers between 1.5L and 1.6L, will the 1.5L work with the 1.6L head? Also I am about to remove the cylinder head like I said because of a broken timing belt, Is there any links for a how to step by step? Its been a while, i remember a few things just want to cross my t's.
Re: 1.5L distributor VS 1.6L distributor (alex17)
use the hf dizzy if your staying obd0 and the ex if your going obd1, they are NOT interchangable. obd0 has 16 click for a full turn and the obd1 had 22 clicks for a full rotation i belive.
hondaswap.com has helms manuals for download for pulling the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex17 »</TD></TR><TR><TD CLASS="quote">
And ofcorse my STD wiring on my 1990 EF STD plugs and plays on the HF distributor.</TD></TR></TABLE>
no it doesnt,,you gotta convert to mpfi to use the hf dizzy.
Re: 1.5L distributor VS 1.6L distributor (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag »</TD></TR><TR><TD CLASS="quote">no it doesnt,,you gotta convert to mpfi to use the hf dizzy.</TD></TR></TABLE> Hey, now you never know if it has been converted
Re: 1.5L distributor VS 1.6L distributor (dr_latino999)
whats the advantage of using the HF distributor if I am going to run mpfi? I pulled off the wire loom cover and its been spliced with another harness, thats why it plugs into dx harness. I also forgot to mention I have a stock 1.5L dx distributor. Will it work with the D16A6 head? Thanks for the link
any specific place to look for the manual? lol
Modified by alex17 at 11:28 AM 9/27/2006
Re: 1.5L distributor VS 1.6L distributor (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">
hondaswap.com has helms manuals for download for pulling the head</TD></TR></TABLE>
dr_latino999
08-18-2005 06:21 AM
15, 15distubiter, 15l, 16, 16l, civic, converting, distributor, distributors, dizzy, fit, honda, interchangeable, put, work
