Code 20 ELD problem help PLEASE!
Old 10-27-2006, 03:36 PM
garybhoy201's Avatar
Default Code 20 ELD problem help PLEASE!
ok, i just finished my mini me swap and before i even began, i had the entire front end off and disconnected all harnesses and the grounds (behind right headlight).
now before i reconnected the ground (little black box with 5 black wires going in) I started it with the 3 main grounds reconnected (valve cover to rad support, battery to trans, and thermo housing). and the car ran great, turning the headlights on or open sunroof etc...caused tach to go nuts, lights dimming and idle rpm to drop.
now I hooked back up all the boxes that attach behind the right headlight and the box that connects to rad support. started the car and it ran ok, except for the same thing happening when i turn on the headlights..eradic idle, drop in rpm, then when i hit the highbeam switch. the car went nuts. it dropped to about 500 rpm and all the lights (except CEL) came on.
now i notice the 20 blinks w/o CEL being on mind you, and the car wont even crank, when i turn ignition to ON position every light except CEL come on, the key chime is very low.
now the battery has good charge, i checked all known grounds and they are tight. the ELD shows voltage, but i noticed instead of it showing 2v like its supposed to when the headlight switch is on low, it shows 12v. (the headlights do not come on when car is off btw).
I am almost completely stumped. Am I missing any grounds? Could it be the Alt? Should I replace fuse box?
oh yeah, btw, the starter fuse (i believe is 14 under dash, seems ok, but when I put a trestlight on it (with key on) it dims all dash lights.
PLEASE if anyone has the slighest clue, and could help, It would be very much appreciated. Thanks in advance!
Old 10-27-2006, 06:35 PM
Default Re: Code 20 ELD problem help PLEASE! (garybhoy201)
anyone? ~bump~
Old 10-27-2006, 10:19 PM
~bump~ anyone? please any suggestions at all are appreciated
Old 10-27-2006, 10:26 PM
crawfo661's Avatar
its a groun in your dash somewhere, like the one by ur hood popper or tha one by ur heat controlls good luck
Old 10-28-2006, 05:42 AM
Default Re: Code 20 ELD problem help PLEASE! (crawfo661)
hmm i didnt mess around back there but Ill check it out, thanks alot.
Old 10-28-2006, 06:18 AM
anyone else have any other suggestions?
Old 10-28-2006, 11:40 AM
bump again
Old 10-28-2006, 10:42 PM
thanks for the No help by the way guys ill figure that wiring **** out by myself...you could have at least mention somthing, you guys are just like them ****** ar crxcommunity.org
bye
Old 10-29-2006, 01:51 AM
Matt067's Avatar
Click on code 20 https://honda-tech.com/zerothread?id=468260
Double check your battery, Try to jump it just to be sure and maybe even check your main relay.
Modified by Matt067 at 2:23 AM 10/29/2006
gxxhxxoxxsxxt
Acura TSX
12
07-19-2014 06:36 AM
FrodeyEJ1
06-13-2012 05:42 AM
joevincett
08-24-2008 07:46 AM
NJcivic21
11-09-2005 11:44 AM
TylerC
08-18-2005 10:28 PM
Quick Reply: Code 20 ELD problem help PLEASE!
