wire tuck help
wire tuck help
hey so ive been doing a mild wire tuck on my 91 si hatch with a b16. i have everything done, except for the fuse box. i have everything plugged in except for the power wire. is there supposed to be 2 wires screwed in? also my battery is relocated in the back, where is the positive wire on the battery supposed to go to? only the fuse box or what. i have the positive wire going into the fuse box but theres a spot next to it, what's supposed to go there? any help is greatly appreciated
Re: wire tuck help ((760)doogie)
here is main fuse box - alternator is white wire - T201 is white wire to dash fuse box, fuse #12 - T202 is white with black stripe to ignition switch - T203 is white with red stripe to dash fuse box, fuse #6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie »</TD></TR><TR><TD CLASS="quote"> where is the positive wire on the battery supposed to go to? only the fuse box or what. i have the positive wire going into the fuse box but theres a spot next to it, what's supposed to go there? any help is greatly appreciated</TD></TR></TABLE>positive from battery goes to main fuse box and to the starter
Re: wire tuck help (jlicrx)
alright, i found the white wire and connected that to the fuse box that was in the engine bay. i didn't touch the main fuse box under the dash. this is a stupid question but where is my starter because the power wire is spliced and i know it went to something and it must be the starter
i hooked up that wire to the started and then i tried to start up the car and it sounded like a fuse blew and it wont even click now.
also there are two boxes with a rubber casing that were mounted in the front of the engine bay. what are those and do they need to be mounted or can i get rid of them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (760)doogie »</TD></TR><TR><TD CLASS="quote">also there are two boxes with a rubber casing that were mounted in the front of the engine bay. what are those and do they need to be mounted or can i get rid of them</TD></TR></TABLE>probably the relays for the cooling fans - where were they located?
they were by where the battery is supposed to be, it has the ac plug for the main fuse box. id idn't connect it because i dont have ac. my car starts now. the weird thing is that my timing belt is loose and it wasn't before i did this. like it can move an inch outward and it hits the plastic casing. how do you tighten the belt?
HondaHemi
11-27-2006 04:38 PM
hatchinprogress
05-02-2006 10:52 AM
