timing on a sohc zc
how do you tighten up the belt i got it timed but my belt is loose..do i just loosen the tensioner and then turn the crank or wat..and if so how many times do i turn the crank
1 Post
Re: (90sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan »</TD></TR><TR><TD CLASS="quote">Get yourself a manual for your car.</TD></TR></TABLE>
agreed, and search.
agreed, and search.
Re: timing on a sohc zc
Usually most timing are required every x0,000 miles. Just get tooth for tooth. No hassle. Should be good and sounds good.
Make sure all the seals are oiled. Job well done.
It times the same as a D16A6. The cam gear has to be lined up at the offset marking, then slide the belt on, turn the engine counter clock wise to get tension on the belt, then tighten the tensioner bolt. Very close to that but ive had both motors. Just dont have my manual in front of me.
nexgen91
12
07-04-2007 06:13 AM
CBURKE
16
01-04-2006 12:58 PM
sporty240
04-25-2004 12:57 AM
