Brake indicator on dashboard stays on
Hello everyone!
I am having issue with the "BRAKE" indicator on the dashboard staying on. I was driving one day then it started flashing then it went solid. Any suggestions?
Re: Brake indicator on dashboard stays on
The BRAKE indicator lamp can be caused by either the brake fluid level switch or the parking brake switch.
Under the hood, disconnect Black Connector C310. If the BRAKE lamp goes out, the issue is related to the brake fluid level switch; the switch may be stuck closed when it should be open (if the fluid level is okay).
U guys rocks! It was the brake fluid switch..it was stuck. I re seated the connections & replaced the cap cover back on..... No more stuck brake light...!
Thank you thank you thank you!
bradtricker
11
05-19-2009 01:32 PM
