code 16 on b16
* B A N N E D *
code 16 on b16
im not really good reading codes but i have a one blink for a long time and then 6 blinks after each other i think i have a code 16 which i think is fuel injectors. can that be the resistor box or it has to be fuel injector?????? when i fire up the car it tries to shut down but it doesnt. it just fails sometimes. what will that be .???????????? and also when i start up the car the ecu gives me more codes but when i turn off the car it only gives me code 16 so any help will be appreciated
Re: code 16 on b16 (juanchoenuncrx)
start by replacing your injector o-rings to ensure a proper seal between the injectors and the fuel rail. they shouldn't cost much at all. if that does not solve the problem, check your wiring. you could also try another resistor box if you have a friend that would just let you try their's for a few minutes to eliminate problems. also would be a good idea to buy a haynes or chiltons manual for trouble shooting procedures.
* B A N N E D *
Re: code 16 on b16 (OldSkoolDa91)
the wiring is fine the resistor box works i have like 3 resitor boxes and its all the same i dont thinkg the 3 of them are all bad abouth the o- ring i;ll try that but i dont think that the o rings will cause a problem
yeah i'd say the box is good then. when my integra through code 16 i went to the junkyard and swiped 4 injectors from another integra and when i was changing them i saw one of my seals was bad but i went ahead and switched the injectors anyhow. so if it's not your o-rings, oh well, you spent like 5 bucks to trouble shoot, then you just take a trip the junkyard and grab some injectors, the new o-rings on them and replace them. good luck man.
Re: (EFRue57)
as long as you take them off of an integra that is obd0. as in a 90 or 91. not sure if the first gen integras ran the same size injectors or not. and im not 100% on the b16s and ls engines using same size injectors, can someone else verify on that one? i don't mess with b16s, never liked them personally.
* B A N N E D *
Re: (EFRue57)
I HAVE BEEN DOING THIS SWAP FOR LIKE 6 MONTHS BUT I HAVENT GET TO DRIVE IT WELL IT HASNT SEEN THE STREETS YET AND THE CAR IS AN 89 HF
HONDABOND
11-09-2003 12:59 AM
