Help fuel problem, sputtering, I think its..........
Hi, I recently swapped from a d15b2 to a obd0 b16A. It starts up fine, but whenever I hit the gas pedal for full throttle, the engine will not respond and it sputters. It goes up to 4 rpm's if I hit the throttle slowly. So my guess is that the fuel filter is bad? I had the same problem on the d15b2......
So, I had some carb cleaner around, and I sprayed inside the TB and accelerated, and it went to redline while spraying.
Do you think a fuel filter could cause a problem like this?
TPS was tested and is working fine.
Re: Help fuel problem, sputtering, I think its.......... (JUN.)
now the car goes up to 8k but when I drive it it bogs sometimes. I think it might be the old fuel.......
94cxhatch
13
06-06-2010 01:24 PM
skidrow2k4
Honda Civic (2001 - 2005)
10-08-2007 08:03 AM
