Distributor Question.
i have a 92 LS motor about to be swapped in a sedan. motor is obd1 and i am wiring the car to obd0 with an obd0 ls ecu. i already have everything to be swapped.
i looked up rewire and they have the obd0 to obd1 conversion harness
i mean can we reverse and do obd1 to obd0??
from Ryans site it says "To use a OBD1 Distributor, you must also be using an OBD1, OBD2a or OBD2b ECU. (OBD Compliant)"
since everything is gonna be obd0 including ecu does dizzy matter? if i just repin to obd0 plugs using this link
https://honda-tech.com/zerothread?id=1349052
better yet, is an OBD1 possible to be used with an OBD0 by de-pinning?
ryanangelo212
03-18-2013 12:23 AM
VegasInvasion
07-01-2010 10:49 AM
ludesrv
05-12-2007 08:58 PM
