seatbelt warning light? HELP
my seatbelt warning light is always beeping just recently no idea why, heres what happened i was driving around with a friend in my car in the backseat he got out so my passenger had to get out of the car to let him out and from then on it just keeps beeping when my car is on, even when i buckle my seatbelt and all the seatbelts it still does it, any ideas how to fix this?
Location: I told you to wait in the truck in Texas, United States
Re: seatbelt warning light? HELP
There is a warning that goes off when the stop/horn fuse blows
that may be the problem..
Does your horn work?
Got brake lights?
Got brake lights?
ya my horn works havent checked my brake lights yet, i was drivin for a while with the wires under the seat disconected and no warning light came on
I have the same damn problem! I had to cut the car off and start it again everytime the passenger side door is open. What would make this go off? My seat belt light works and 2 lights above the mirror works just fine.
behind the center console on the passenger side, theres a black lid you pop off. unplug the green plug, that fixed my dinging and light for seatbelts
i unplugged the beaping thing above the rear view mirror and just the light on my cluster flashes and i got into my car today and all of a sudden it just stopped flashing and i did nothing real weird
the plugs inside your door panel that connects to your seatbelt thing or motor whtver you called that thing might of gone bad. take your door panel off and check for a loose connection. wiggle the plugs on the seat belt while the car is running to see if that triggers it.
freshly boosted DOHC ZC
11
12-28-2008 07:49 AM
Brownjd
10-17-2003 06:52 AM
