Car hard to start in the Morning ..Help !!
90 civic ef
hard to start in the morning or when it sits there for a while ....but after it turns on everything runs fine !!! need help thanks
Re: Car hard to start in the Morning ..Help !!
What do you mean it's hard to start? Like the motor turns over slowly or does the starter just click? or the car turns over but just doesnt start up?
No cel when i start car but after a while of drive and car and motor is hot the lights comes on...tune up is okay new spark plug oil change new fuel filter fixed fuel evap...main relay is fine ...maybe the ignator ?? or starter ?
Who the fack changed my title?!
some times my car clicks like the clutch signal isnt all the way pushed in but meh, what do i know
Code 23 is the knock sensor.
Get a compression tester, and test the engine when it's cold and when it's "hot" (warmed up).
im getttin different answer from other ppl....its the ignitor... i have fuel problem blah blah all that ...
just out of curiosity, which engine and ecu do you have?
at first i thought you had an obd0 setup, but after seeing code 23 come up i'm guessing your running obd1?
Well, there's your answer. It's hard to start because you're running untuned and dumping in 1.6L worth of startup fuel plus cold-cranking enrichments and you're only running a 1.5L.
Try cracking the throttle a little bit next time you start it cold (maybe 5%), it'll probably start more easily.
ef9_pr0jekt
03-07-2020 07:44 AM
mister.wong
09-13-2008 04:45 PM
slowmotion4x4
06-11-2008 07:21 PM
