how to bring in the wheels a little?
if i wanted to bring in the front and rear wheels cause the wheels stick out a little are there any lower control arms available for the ef?
Re: how to bring in the wheels a little?
Buying lca's won't adjust the width or bring in the wheels. If you managed to get shorter lca's it would only bring the bottom of the wheel in, resulting in positive camber and goofy suspension geometry. You could put some fender flares on it...
Replacing wheels is how you will bring them in under the car. However if you wanted to push them out there are a few options...
camber kits will help bring in the top but i wanted to bring it in evenly top and bottom.
so the geometry wont be affected.
are those some reverse dayton wire wheels? LOL
hope not but anyway get some bad *** wide body fenders to cover that **** up
you guys are answering someone else's question.
thats not even my car.
my wheels dont come out that far. maybe about 5mm or so.
why don't you just bring your fenders out a little; any body shop will be able to do that;
something like that if you don't have a rim that is too wide;
http://www.youtube.com/watch?v=QHM-A_aFCoY
to answer your question.. yes for the rear at least:
http://www.summitracing.com/search/b.../?autoview=SKU
combined with an upper camber arm it can bring in the wheel a bit.
As for the fronts, there aren't any shorter arms that I know of. You would need to do a combo of fender rolling / over fenders as other people stated.
