what wire to cut?
what wire to cut?
what wire can i cut at my ecu to make my car not start...(for a kill switch)
tia
tia
Re: what wire to cut?
you should put that its for a kill switch in your original post so that people dont get confused and think that you are nutz...!!!
i guess kill power to my ecu. its the closest thing to my kill switch so figured it would be the easiest...im having trouble tho i tried, A2,A16,A18,B1,B10,C1
so you tried the kill switch on each of them wires? and it still started? b10 killed should not started
i think ud be better of on the starter wire
any real car thieve will listen if the fuel pump is getting power. its the most common kill switch.
no one knows what wire will not make my car start at the ecu
T-RO
12-02-2004 02:21 AM
