fuel pump???
Old Dec 3, 2008 | 10:12 AM
ninety7_civic's Avatar
Default fuel pump???
just went turbo but not tuned yet.was wondering if a fuel pump will make any diffrence installing it after im tuned. and if its nessecary if im looking to make around 170whp i heard you only need a bigger one if your making over 200whp.im running a y8 and its all stock.planning on getting tuned at 7 pounds. let me know what you guys think.
Old Dec 3, 2008 | 10:34 AM
MadVTI's Avatar
If fuel pressure remains the same then id say it will be fine.
Old Dec 3, 2008 | 10:36 AM
Schister66's Avatar
Man U FTW
Just throw a Walbro 255 in for peace of mind if nothing else. Since the FPR will regulate your pressure to the stock level, you'll be fine. The extra fuel will recirc anyway.
Old Dec 3, 2008 | 10:49 AM
but will it throw my car out of tune if i put in a fuel pump after tuning.im on a budget and im trying to get tuned asap.
Old Dec 3, 2008 | 11:00 AM
Turbo-LS's Avatar
If your on a budget then you shouldnt be rushing to get tuned and hammer the car. Budget means you cant afford to fix it if it detonates on the rollers due to lack of fueling. Save up the 100 bucks for the walbro.
Old Dec 3, 2008 | 12:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
worst case scenerio, the fuel pressure goes up a little if the stock reg cant handle the output from the walbro.
Old Dec 3, 2008 | 12:39 PM
HiProfile's Avatar
The 255's sometimes raise idle fuel pressure by about 10psi depending on what stock FPR you have. From what I know the dohc vtec motors use a slightly larger FPR due to the larger stock pump.
Regardless, the 10psi will ONLY be at very low load/rpm points. If you maintain the stock fuel pressure, there will be no change in the tune for boost - unless you were running out of fuel before.
CFDOHCVTECEG
Feb 2, 2007 03:32 PM
GS-R Civic
Dec 2, 2005 06:57 PM
B16CRXT
Aug 29, 2004 11:06 PM
ATS*Mark
Nov 4, 2003 05:11 AM
Lsos
Jan 16, 2003 11:56 AM
