Time delay relay to control nitrous solenoid
I am trying to find a time delay relay that will delay my nitrous solenoid a couple tenths of a second. I need one that is ground triggered. Im trying to do this because i believe my nitrous is beating my fuel to the motor and my afr is extremely lean for a split second. Any suggestions would be greatly appreciated.
josh
josh
well, i have a dp kit with stainless steel lines. i could buy 4 more that are longer, but i would rather use a time delay relay or switch.
i might be able to use the dyno tune switch but im not sure if it can be triggered by a ground. im using a zex wot switch that grounds my solenoids when im at wot.
dyno tune controller is very nice but I wouldn't use it to control that. Just adjust length of the lines or if you got hondata s300 you can use it to controll nitrous and adjust for extra fuel when nitrous is on by rpm. so just add fuel where it goes lean. BTW s300 with nitrous controller is the **** when it comes to having the car tuned out and nitrous controll. You can make sure that all the power goes down to the ground, make sure that afr is good, and nitrous is kicking in at the right RPM. I think nitrous controller is a must with anything over 50hp shot.
