which turbo??
Old Dec 14, 2008 | 01:58 PM
bjones's Avatar
Default which turbo??
http://cheapturbo.stores.yahoo.net/pebtokit.html
i have the chance to pick this turbo kit up locally for a good price, but i comes with everything EXCEPT the turbo. i was wondering what would be a good turbo for 450-500whp. my setup will be
gsr block: 81mm
block guard
eagle rods
cp pistons 9:8:1
arp main and head studs
moroso oil pan
new oem water pump&oil pump.
stock gsr head:
new valve seals, etc
Edelbrock VictorX Intake Manifold (port matched)
bigger throttle body(undecided at time, also port matched)
1000cc injectors
walbro fuel pump.. blah blah you get the idea
gsr lsd tranny
btw it will tuned on E85. thanks for the ideas in adavance
Old Dec 14, 2008 | 02:04 PM
Turbocivic94's Avatar
GT35R
SC61
and bunch others
Old Dec 14, 2008 | 02:41 PM
1KWHP1G's Avatar
+1 I use to run an SC-6152E in my 1G Talon.On my 2.0 liter it generated 384whp on 20psi on 93 octane.On C16 and 30+.psi it made 550whp.It would spool pretty hard 2nd gear at 6,200rpm's.Good street/strip turbo !
Old Dec 14, 2008 | 02:44 PM
Schister66's Avatar
Man U FTW
Borg Warner S258 will do the job no problem and will do so without as much lag as any of the other suggestions
Old Dec 14, 2008 | 02:48 PM
1KWHP1G's Avatar
You'll be way happier with a ball bearing unit for the street.Spools up quicker than a non-ball bearing turbo,and handles high levels of boost for long periods of time better.If this was going in a drag car with nitrous than you could get away with the non-BB version but since this is a street car I'd try to stick with a BB turbo.
Old Dec 14, 2008 | 02:49 PM
1KWHP1G's Avatar
Definately,thats a good turbo too.
Old Dec 14, 2008 | 03:12 PM
black_EM1's Avatar
Community Builder
Community Influencer
I'm guessing he's trying to stay within a budget and BB turbos aren't getting any cheaper. That said, I love my 30R.
Old Dec 14, 2008 | 03:13 PM
bjones's Avatar
its going to be weekend fun car\ track use. im trying to stay within a budget.. where does the 30r start to spool around??
Last edited by bjones; Dec 14, 2008 at 03:17 PM. Reason: saw post i havent read yet
Old Dec 14, 2008 | 03:35 PM
extralargenog's Avatar
Spool iis negligably better... Transient response is notixable y improved, but spool isnt that much quicker.
Old Dec 14, 2008 | 11:45 PM
Schister66's Avatar
Man U FTW
Obviously you dont understand what a BB CHRA really does. The bearing package alone doesn't increase spool time. Its the combo of the wheel design and the bearings. The above statement is pretty ignorant. Please, dont suggest things if you're offering incorrect information
An S258 compared to a GT35r....you're going to notice a good amount of difference in spool between the two.
Old Dec 15, 2008 | 12:09 AM
I would think that a 258 would outspool the 35r by a bit... I was saying that the guy that INSISTS that the BB CRHA spools so much faster than a JB style is wrong. The transient recovery IS faster for sure though... Curious as toi how rthe BWS compare... I cant find any dynos of a Built H with one VS 61mm GArrett,
WOuld sure like to see some.
My ? is how much of a difference is there between a divided .83 s366 and a 61mm garret unit.... or a 67mm garret unit??? Ive been witing for one of you BW pushers to chime in on the thread I started..
\ threadjack.
Old Dec 15, 2008 | 06:29 AM
spoolin turbo s's Avatar
when you say 450-500 do you want that on pump gas or just on high boost and race gas?
also when you say budget....how much are you willing to spend if you answer those 2 im sure one of us on here could tell you exactly what would fit the criteria you have set
Old Dec 15, 2008 | 07:27 AM
black_EM1's Avatar
Community Builder
You're going to need a larger medium frame turbo like the others suggested such as the 35R, S258, etc. The Garrett units are going to be a little more expensive, over the $1k mark apiece.
My setup was similar to yours, but with a B16 head, AEBS IM, and 750cc. It made 418whp @17psi on a GT3076R. Full boost by 4500 and power past redline, it just kept climbing. It was beautiful.
Old Dec 15, 2008 | 07:32 AM
bjones's Avatar
it will be tuned on e85. i know the price of turbos and how much they are and im willing to spend 1k plus for a turbo i was just wondering what you guys would recommend. with the gt3076r would you say the 38mm wastegate is good enough or would you upgrade to 44mm??
Old Dec 15, 2008 | 07:49 AM
black_EM1's Avatar
Community Builder
38mm will be fine. Again, I have to stress that this turbo wil be breahing hard at 525, but that's above your goals anyway.
I'm sorry but I have no experience with e85.
Old Dec 15, 2008 | 11:11 AM
1KWHP1G's Avatar
You know what? I'm not a bench racer.I know what I know from personal experience.You sound ignorant just for being so quick to throw the word around.There are more variables to spool time than just the bearing,obviously.wheel diameter,A/R ,I/C piping,and so on.However,the BB version of any turbo will spool up quicker than the non-BB version.
Old Dec 15, 2008 | 02:32 PM
GEN2 LS's Avatar
Loved
i'd go with the Garrett T3 60-1 .63 hotside works great on a b16 i'd imagine even better on a 1.8. There is some lag, but top end if def. there. Plus you should make 500whp on it without a hitch.
92egkirt
Dec 5, 2011 02:09 PM
RSant
Dec 19, 2007 03:13 PM
Jdm integra DB8
Feb 2, 2007 04:15 PM
aznegg
Jun 25, 2006 07:18 AM
