? what fuel injectors should i use ?
hello i am building a 92 integra ls turbo i will use wiseco pistons eagle rods racing bearings arp head studs and 2.5 inch pipe turbo back with high flow muffler and cat to get 350/400 whp with a borg warner 57 trim what injector sise should i use 550 660 1000 cc ?
any help is appreciated
Man U FTW
First of all i would suggest getting a 3" exhaust if you're shooting for 400whp with that turbo. As for the injectors, you could use 1000cc's...the others will be too small. You could also use 880cc's if you're on pump gas or race gas; however, E85 would require 1000s for leeway
