Direct Port Nitrous
Old Dec 11, 2008 | 01:26 PM
lude98SH's Avatar
Default Direct Port Nitrous
Well I have an h22a. My setup is:
H22a with stock bottom end.
BPI velocity Stack
AEM 3 inch intake
68mm AEBS TB
Accord Euro R manifold plenum portmatched to TB and runners ported
PP head
3 angle valve job on intake and radius on exhaust
Skunk2 Stage 1 Cams
Supertech Flat faced valves
Supertech valve springs
Supertech titanium retainers
Single Layer Headgasket
KaizenSpeed BalanceShaft Eliminator kit
Lightweight Flywheel
UR ultra R crank pulley
Camp1320 header (open)
The CR is approx. 11.3:1 (zealautowerks)
What kind of shot could I run on this ? Direct Port should be alittle safer than a regular nozzle setup wet or dry kit...correct ?
Old Dec 11, 2008 | 02:56 PM
91VTECREX's Avatar
definitely go direct port its so much better. try to go equal length if you have the means and i would say you could run up to a 100 shot... we ran 100 shot in my buddies b16 at about 11.7:1 compression with direct port injection and the car has now been running on nitrous for almost three years no problem... oh and its a daily driver.
Old Dec 11, 2008 | 02:57 PM
Jas9848's Avatar
100 shot tuned by someone who knows what theyre doing. you can run it in the intake tube for that size shot. i wouldnt but its been done by alot of people
lude98SH
Apr 17, 2009 04:09 PM
lude98SH
Apr 17, 2009 04:25 AM
scUba-stEve
Apr 20, 2005 08:20 PM
bottlefedb18c1
Jun 2, 2003 08:17 AM
B19CivicHB
May 15, 2002 05:21 PM
