JE or Wiseco piston?
Old Nov 30, 2008 | 05:39 PM
stockb18c's Avatar
Default JE or Wiseco piston?
i have a b16 81 stock bore building the bottom end 9:1 compression pistons...trying to find out which one to go with and was wonder what you guys think which is better...
Old Nov 30, 2008 | 06:32 PM
EARLdaSQUIRREL's Avatar
official honda whore
81.5mm will work with either, i would bore it .20 over and go with wiseco personally
Old Nov 30, 2008 | 07:50 PM
ITR-EKcoupe's Avatar
ive read that after around 600 horse the wiseco's get weak. so in other words if you a normal person wiseco's will do just fine.
Old Nov 30, 2008 | 07:52 PM
tegman23's Avatar
X2 9:1 wiseco here 81.5 no problems...they even lasted cracking a sleeved and still holding strong
Old Dec 1, 2008 | 07:18 AM
irishflame27's Avatar
either or is a good choice
Old Dec 1, 2008 | 07:27 AM
miller's Avatar
They both make a very quality product.
Old Dec 1, 2008 | 01:11 PM
96 GSR-T's Avatar
I have read about issues with the Wiseco's failing above 600whp also, supposively the pins are weak and the skirts are weak too. I run them too at 81.5mm and I am just shy of 600whp now and it has me very nervous, I would go with JE's or spend a few extra $$'s for the peace of mind and get CP's.
Old Dec 1, 2008 | 02:15 PM
nonvtecallmotor's Avatar
I've ran them both in my engine. I've never had an issue. If you are trying to make 800whp get the upgraded wrist pins. All the piston makers sell upgraded pins.......
Old Dec 1, 2008 | 05:54 PM
boosted hybrid's Avatar
The "shelf" wiseco stuff does not have a well designed skirt/boxed area of the piston. I just recently had a customers engine on the dyno rip the wrist pin from the piston in this area. I cannot comment on the wrist pin strength as I have never personally damaged a set. The endyn wiseco piston design looks more like the JE and CP box/skirt. The shelf wiseco piston skirt/box design looks more like the "x-skirt" all motor pistons from CP.
Old Dec 1, 2008 | 06:11 PM
rota92
Guest
Posts: n/a
Brad/RLZ's Wiseco is a great unit as well. If the OP needs contact info for RLZ pm me and I'll send Brads stuff right over
Old Dec 1, 2008 | 06:53 PM
stockb18c's Avatar
thanks guys you your comments
Old Dec 1, 2008 | 08:22 PM
ralph11sec's Avatar
its just a preference. both are excellent
Old Dec 2, 2008 | 12:41 AM
Cyber ITR's Avatar
so if i have a stock shelf wiseco pistons , can i buy the upgraded pins by themselves ?
Old Dec 2, 2008 | 02:39 AM
ralph11sec's Avatar
yes. u can, if im not mistaken its about 80bucks
Old Dec 2, 2008 | 05:03 AM
reboosted's Avatar
ive been waiting 6 months on a set of pistons from them
Old Dec 2, 2008 | 05:23 AM
96 GSR-T's Avatar
correct, but the upgraded pins wont stop them from ripping out from the weakened skirt like what Jeff described happened to him on his dyno.
Here is a link to the thread that I started about these pistons.... https://honda-tech.com/forums/showth...ghlight=wiseco
Old Dec 2, 2008 | 07:56 AM
hondaapi's Avatar
If the Wiseco would be sooo bad, than I do not understand why JeffEvans sells them in the EvansTuning online store?
I trust him and Andrea a lot but this confuses me a little...
Old Dec 2, 2008 | 10:29 AM
96 GSR-T's Avatar
They are good for your average build up to about 500-700whp, after that its better to run a different piston. There is a guy on this site making almost 900whp on shelf Wiseco's with the upgraded pins, probably not the best idea but it can be done. Just like Eagle Rods shouldnt but can be used in a 900whp engine, better to use something else.
Plus nobody said here that they are soooo bad, simply stated that above a certain power level some are failing miserably.
Old Dec 2, 2008 | 02:24 PM
Because the majority of the people that are building hondas are not looking to make 650-700whp+. The wisecos are an excellent shelf piston for someone looking to upgrade for a street car. If you look at our engine packages we offer, the stage 1 comes with wiseco and we rated it at 500whp. The stage 2 and 3 builds use CP's.
Old Dec 3, 2008 | 04:00 AM
stockb18c's Avatar
ya im only lookin for 350-400whp on the street any more would be to much..never track the car so hopefully that should be good
Old Dec 3, 2008 | 04:58 AM
96 GSR-T's Avatar
you should be ok, I am making 585whp on shelf Wiseco's and I put about 3k hard miles on the car this summer, at or above 500whp constantly. I like these pistons too because they seem to be quieter than my old JE's and they are definately quieter than my friends CP's in his car.
Old Dec 3, 2008 | 07:36 AM
hondaapi's Avatar
Yes, they are usually quieter because the wristpin is a little off centre.
Old Dec 3, 2008 | 08:07 AM
stockb18c's Avatar
with you guys build did you dyno right after start up or break in miles cause last build i went about 100 miles and street tune it and still running strong today..just wonder what people do on there builds
Old Dec 3, 2008 | 08:59 AM
96 GSR-T's Avatar
I put 1500 miles on my fresh bottom end N/A, and then had Jeff E tune the car.
Old Dec 3, 2008 | 10:30 AM
:Josh:'s Avatar
JE, CP, Wiseco, pretty much any piston manufactured in California the wrist pin is on center.
