best cam for power
Old Dec 14, 2008 | 02:28 AM
BLT4SIN's Avatar
Default best cam for power
so im boosting my stock gsr, and plan on building the bottom end and head later on down the road. and figured id go ahead and knock cams out of the picture now. ive heard type r cams are the route alot of people go and make alot of power with, but i had been looking at crower cams and JUN cams to use. anyone have any experience with cams to help me out?
Old Dec 14, 2008 | 06:56 AM
Boston_George's Avatar
Depends on your WHP goal & setup, but both OEM GSR and ITR cams work well.
OEM GSR cams 200-300 hp
OEM ITR/CTR cams 300-400 hp
Old Dec 14, 2008 | 08:54 AM
got wide's Avatar
skunk2 pro 1's check em out
Old Dec 14, 2008 | 10:08 AM
Boner_Ben's Avatar
Stock gsr's work well and go 9's
Old Dec 14, 2008 | 12:33 PM
delslo93's Avatar
I love my blox pro 1's. But unless you have dual valve springs and titanium retainers and an LMA upgrade they aren't recommended. Even with the type R cam's I would want to have valve train and an LMA upgrade. So until you have the money to upgrade the valve trains and LMA's I would go with GSR's.
Old Dec 14, 2008 | 12:37 PM
black_EM1's Avatar
Community Builder
Community Influencer
As far as OEM, I'd say ITR. GSR cams make good power as well. I've seen ITR cams in 600-700hp cars, so they work.
For aftermarket, the Skunk2 Pro1s seem to be the way to go. Of course, you'll need everything else that goes with them headwise.
Old Dec 14, 2008 | 05:07 PM
rustydusty1717's Avatar
I've got stage 3 turbo cams from Brian Crower, and they work great.
Old Dec 14, 2008 | 08:02 PM
tony413's Avatar
what an over asked question. 97 itr/ctr cams or skunk2 tuner 1's
Old Dec 15, 2008 | 04:27 PM
mike_s13_drift's Avatar
stick with stock
Old Dec 15, 2008 | 05:10 PM
tegman23's Avatar
x2
Old Dec 15, 2008 | 07:53 PM
blinx9900's Avatar
buddyclub stage 6
Old Dec 16, 2008 | 07:19 AM
TheShodan's Avatar
Moderator
Originally Posted by blinx9900
buddyclub stage 6
buahahahaha..
Old Dec 16, 2008 | 07:33 AM
Garcia-Racing's Avatar
Comp cams makes an excellent turbo grind. I don't remember the part number but it was the more aggressive of the 2. We made great power with them.
Old Dec 16, 2008 | 11:30 AM
TheShodan's Avatar
Moderator
300whp, there's no need for a cam other than a GS-R. These other big NA cams like the Pro1s are for much bigger applications in which they are warranted.
Save your money, put it towards good turbo parts and tuning time.
Old Dec 16, 2008 | 05:03 PM
jdm602's Avatar
gsr's would be good enough, but the newer itr's/ctr's are like the best factory cams for bseries. theres quite a bit of difference between them...and price too.
then might as well do valve springs and retainers too. i would recommend supertechs.
Old Dec 16, 2008 | 05:26 PM
J.Berta's Avatar
gsr cams worked good for me. Friends of mine made up to/over 900 whp on them The newer itr cams have more valve over lap than the older ones. You don't want alot of over lap.
Old Dec 16, 2008 | 11:26 PM
jdm602's Avatar
overlap is overrated.
Old Dec 17, 2008 | 12:29 AM
tony413's Avatar
thats funny. so when im running 1.5:1 backpressure or 1:1(doubt it) i think im going to want the over lap because the engine is behaving like an N/A
Old Dec 17, 2008 | 10:52 AM
jdm602's Avatar
lol thats is funny.
with some wicked na cams you prolly will have some overlap.
but ive seen some cars that are running the itr's/ctr's and have next to no overlap.
ITR STOCK GEARS 816WHP http://www.turbooptions.com/video/camgers.wmv
Old Dec 17, 2008 | 12:35 PM
tony413's Avatar
lol thats is funny.
umm i didnt see any dyno ??? i just seen some guy running his mouth
also i dont think you understand what i said in my post. if your car have TONS OF backpressure then you DO NOT want overlap (pretty common sense). if your car has LITTLE backpressure TO CROSSOVER the YOU DO want cams that have overlap because the car is behaving like an N/A motor. what happens to N/A motors when you stick in cams that have a little overlap ?
Old Dec 17, 2008 | 01:30 PM
jdm602's Avatar
ok i dont understand.
sounds to me like na cams are the way to go if you can avoid overlap, i see people saying that turbo cams arent that aggresive as far as lift and duration.
anyways, back to the main point, itr's/ctr's/s2 pro 1's/blox b's and even gsr's seem like a decent choice for cams. whether you want to argue about overlap talk to the expert, tony413.
oh and btw, i've seen gsr cams make more than 300 personally...460 wheel...same with the itr's/ctr's...754.
Old Dec 17, 2008 | 01:55 PM
tony413's Avatar
turbo cams are usually made for cars that come turbo form the factory. they usually blow on turbo honda's. also you missed the point yet again large N/A cams are going to have overlap unless you degree out the overlap.
Old Dec 17, 2008 | 02:10 PM
jdm602's Avatar
did you not read?
sounds to me like na cams are the way to go <b>if you can avoid overlap</b>
meaning get some cam gears if you have it to degree it out.
Old Dec 17, 2008 | 05:24 PM
tony413's Avatar
PM me or i'll PM you i can give you a full explaination because it doesnt exactly deal with this main topic of "what cams to get"
Old Dec 19, 2008 | 08:44 PM
boostfed-r's Avatar
ITR all the way!
