block ok to use?
Old Dec 13, 2008 | 09:57 PM
top end tuner's Avatar
Default block ok to use?
i recently was given a b18c bare block which has a chunk missing to the bottom of cylinder 1. ive heard that it was ok to use and that it wasnt. I have also heard that it looks similar to block notching so it will be fine. i need some input if it is ok to use and also if it is ok for boost?
reference picture not actual but similar
Old Dec 14, 2008 | 07:39 AM
bump need answers
Old Dec 14, 2008 | 07:43 AM
black_EM1's Avatar
Community Builder
Community Influencer
So the "chunk" is on the outside of the block?
Old Dec 14, 2008 | 09:02 AM
got wide's Avatar
^^no look at the bottom of the cylinder on the left were the rod has hit it.
op, as long as the bores straight and not cracked and the main bores are ok it should be good to use. you could also look into sleeving it.
Old Dec 14, 2008 | 10:30 AM
ITR-EKcoupe's Avatar
looks like the rod bearing spun and the rod was hitting the bottom of the cylinder. how far up the bore does it go or is it just at the bottom of the sleeve? if its not too far up the bore and theres nothing to damage the piston it should be ok. take it to a machine shop, they will be able to tell you forsure.
Old Dec 14, 2008 | 10:38 AM
bobby taylor's Avatar
fill the rail in with weld and sand the bore where the rod hit
an run it like you stole it!
Old Dec 14, 2008 | 06:54 PM
96bstdgsr's Avatar
it will be fine mine sucked up water and the rod bent it looked identical to that and it is fine havent had any problems
Old Dec 14, 2008 | 07:36 PM
1991civicsi's Avatar
Looks to me someone began notching the block to accomodate a set of rods but gave up. lol
Old Dec 14, 2008 | 07:39 PM
stockb18c's Avatar
Just make sure there's no cracks in the sleeve cause that would just
Be a waste u know
Old Dec 14, 2008 | 08:02 PM
H9Omega's Avatar
The block is goos to go, you'll be fine.
Old Dec 14, 2008 | 09:00 PM
thank you guys for the input im glad to see honda-tech is still a helpful resource
97grnrs
Aug 8, 2008 03:37 PM
neil-ste
Jan 26, 2008 03:29 PM
RyanA
Jul 17, 2007 04:14 PM
92BlackSi
Aug 31, 2003 08:41 AM
Apex i ITR
Aug 12, 2002 01:34 PM
