Replace ARP Headstuds? need opinions
Old Dec 12, 2008 | 08:51 AM
1SlowSi's Avatar
Default Replace ARP Headstuds? need opinions
Right now i am in the process of trying to figure out why my coolant overflow keeps filling up. Some people say that my head is lifting which i find hard to believe on such a new motor and fresh studs. If it boils down to changing the headgasket, should i replace the ARPs as well? The motor only has 300 miles on it and has been torqued twice. The initial 70ft lbs, then re-torqued after 10 heat cycles to 75 ft lbs.
So what would you guys do as far as new headstuds?
Old Dec 12, 2008 | 12:07 PM
jarvis199's Avatar
no, u dont need to replace the arp's...
at least i wouldnt...
what headgasket did u use? are u sure the head and block surfaces are flat?
Old Dec 12, 2008 | 03:50 PM
a1320addict's Avatar
Most of the new ARP sets are coming with instructions stating to torque to 80 ft/lbs.
Old Dec 12, 2008 | 04:44 PM
1SlowSi's Avatar
The block and head are good to go. Both shops that did the head and block stated they were perfect. Lets hope that statement was 100% true and tested.
im using a cometic head gasket. Im gonna pull the head and put in a golden eagle headgasket and see what happens. lets hope all is well.
Old Dec 13, 2008 | 01:18 AM
blinx9900's Avatar
i was about to say that i always tq'd mine to 80
Old Dec 13, 2008 | 06:56 AM
riceburner700's Avatar
who did the computer tuning, to much timing can start to lift a head as well
Old Dec 13, 2008 | 08:41 AM
Ericy321's Avatar
Shouldnt need to replace the studs though. Those should be good forever if torqued corrrectly.
Old Dec 13, 2008 | 09:28 AM
WalkerGSR1's Avatar
Alot of people have problems with cometic HG blowing on boosted hondas, try an Oem headgasket.
Old Dec 13, 2008 | 10:32 PM
NewUnit16's Avatar
dont know about hondas, but on my VW i have ARP's. like everyone has said, they're good for a lifetime if you torque them right, they dont stretch like OEM ones do. also, i never had to retorque them after a "break in" period.
Old Dec 13, 2008 | 11:54 PM
CoreyR's Avatar
theres been a lot of threads lately with the same complaints and the one thing they all have in common is cometic gaskets.
try an OEM gasket. if you need something larger then 81mm golden eagle makes overbore stock gaskets up to whatever size sleeve you have.
Old Dec 14, 2008 | 12:46 AM
blinx9900's Avatar
funny thing is i have nothing but success with cometic and thats with honda's, dsms and subarus...
Old Dec 14, 2008 | 05:14 PM
1SlowSi's Avatar
I did the tuning. At 14 psi im running about 19 degrees of table timing using S300. The plugs show that its fairly conservative and still has room for advance but its strong as hell how it is now.
Old Dec 14, 2008 | 05:35 PM
rintegration's Avatar
Is this a sleeved block & O-ringed block?
Old Dec 14, 2008 | 06:08 PM
1SlowSi's Avatar
stock sleeves
ChRiS_p123
Apr 8, 2010 10:27 PM
97gsrki
Oct 13, 2006 12:42 PM
G2Crash
Jun 13, 2004 02:56 AM
staticrex
Jan 23, 2004 01:39 PM
servion
Mar 7, 2003 08:35 PM
