Integra Injector Wiring Colors....and What is Their Order??
Here is the story: I had to change my head gasket. I did so and in the mean time i went ahead and bought a new Intake manifold. Well I had to cut and splice my injector wires to extend them for my new intake manifold. They are all practically the same size now. I think i might have mixed up the wires for the injectors for cyl 3 and 4. Now I searched and found this:
Injector #1 (closest to driver's side)
solid brown wire
yellow wire w/ black stripe
Injector #2
solid red wire
Injector #3
solid blue wire
Injector #4
solid yellow wire
Is this correct?? I am pretty sure i mixed up these wires because I started the car after all was said and done the car had a flashing CEL, which after searching means a bad misfire. Now will mixing up the injector wires cause a flashing CEL, misfire??? Also could starting it with this misfire damage anything?? TIA!
solid brown wire
Injector #2
solid red wire
Injector #3
solid blue wire
Injector #4
solid yellow wire
well i know the polarity of the wires doesnt matter, i.e. i have after market injector clips that came with pigtails and both of the wires are white.
the yellow with a black stripe is the ground, the colored wire is the power wire, just double check all connections but it sounds like u did everything correct just might not have a solid connection.
alrighty i figure it out. since i have hondata and the sensor for the water temp was broken that is why the check engine light was sort of flashing. also my idle air control valve needs to be cleaned... everything is running great other than that, thanks guys!
95dc2teg
12-15-2008 08:47 PM
Tippyman
14
03-27-2006 08:55 PM
Mr. Vapor
04-27-2005 12:29 PM
